Sending fork for wa...
[Closed] Sending fork for warranty should I remove crown race?
Sending fork for warranty should I remove crown race? Never done that before.
Posted : 29/10/2014 12:01 am
I would - if you get a new fork you'll be stuck without the race?
Posted : 29/10/2014 12:02 am
wot he said
Posted : 29/10/2014 12:03 am
Yep, I once sent back a Reverb under warranty, they repaired it but then didn't send back the little bit of plastic that controls the cable when you compress, the top part of the saddle clamp, the 2 nuts that sit in that clamp or the 2 bolts to connect everything up!
Posted : 29/10/2014 12:07 am
Any tips for getting it off?
Well I went with grease, hammer and flat head screwdriver came off in about 60 seconds. When I found out a replacement race was £20 I definitely wanted it off
Posted : 29/10/2014 12:24 am
