See those Bird hard...
[Closed] See those Bird hardtails...
I don't think many people need bigger than a 19 1/2in frame.
[img] http://tingilinde.typepad.com/.a/6a00d83451b54669e2012877aaa47b970c-640wi [/img]
Posted : 15/08/2014 5:21 pm
Ben you doing different colours then?
Posted : 15/08/2014 6:09 pm
 LoCo
Oi! I do, with a nice long toptube too 😉
Posted : 15/08/2014 6:18 pm
For the love of god do something about your lawn benpinnick.
Good looking bike though.
Posted : 15/08/2014 6:21 pm
*Interested*
What's your saddle rail to BB centre dimension?
Posted : 15/08/2014 6:34 pm
BenPinnick
@thisisnotaspoon - the geo on Dirt is actually slightly wrong (my bad but its not that wrong so I wont get them to correct it), the Bird Aeris sizing is:
380 425 445 465 490 mm
or 15.0 16.7 17.5 18.3 19.3 in old money.
And thats with a full spread of ETTs.
So I am with you 100%.
Are you the chap I met at the London Bike Show?
Posted : 15/08/2014 6:36 pm
yep thats me.
Posted : 15/08/2014 6:41 pm
yep thats me
<thumbsupicon>
Posted : 15/08/2014 6:47 pm
benpinnick - Member
Not going to tell you how to do your job, but, I'd get it fixed if I was you- there's tons of us nerds out there that like numbers. It doesn't make any real difference but we don't care.
Posted : 15/08/2014 6:55 pm
Is the BB drop right?
[url= http://dirtmountainbike.com/fresh-produce/fresh-produce-orbea-rallon-x-team.html#!bD2zEx ]Jones said this had a really cool BB height, but yours is lower.[/url]
Posted : 15/08/2014 7:00 pm
Yeah its right brant - its low... not sure whats lower out there but I do know we'll not be making it any lower any time soon. we run 170 cranks (or 165s) rather than 175 and bashes across the range to keep the pesky rocks in check though.
Posted : 15/08/2014 7:57 pm
Good work guys! I'm thinking 170mm cranks make more sense than 175mm for average height riders with the propensity for low BBs on modern geometry. I noticed the geo chart looking strange because the BB height was lower with the 150mm travel but the angles steeper, which is obviously the wrong way around.
Anyone curious about how suspension works, go on linkagedesign.blogspot, use google translate if you dont' speak Spanish, and try to get your head around the graphs. It's incredible how different the performance of two 4-bar systems can be, simply through small changes in pivot location. It's also pretty amazing how a single pivot like an Orange 5 can be made to pedal really well - but you're restricted with leverage rate and there's also the issue of lateral rigidity without other linkages.
Posted : 15/08/2014 8:09 pm
Agreed, I ride 170s and am distinctly average, I think Sheldon's formula put me on about 167mm.
I get no pedal strikes on my Nimble 9 (On my old Blur, with 175s, it was a curse).
Posted : 15/08/2014 8:27 pm
This looks smart.... What other colours will it be available in?
Posted : 15/08/2014 9:44 pm
No, its the right way round - on the Aeris anyhow. The sagged geo (contrary to popular opinion sagging an FS does effect its geo) is what you would expect, but the linkage positions don't work like most bikes, you are changing the geo so it starts steeper/higher, but ends lower by a touch - more importantly its giving a different shock curve in 140 that 150. 150 is more resistant to bottoming while 140 has a longer 'sweet spot' where the shock is very supple in the mid stroke.
Tangerine Orange, Stormtrooper white, Bigfoot blue, Very Lime green and black as the night.
Posted : 15/08/2014 10:46 pm
Saw one today at the ukge. Very nice looking too
Posted : 15/08/2014 11:11 pm
Yes, it's often misunderstood! It looks like the bike sits deeper in its travel at 150mm (30% sag) than at 140mm (21%). Is that due to the leverage curve or does it require changing the shock pressure? Your charts are with 531mm A-C which I guess is with one of the 140mm forks, so they'll be a bit slacker and taller with the 150mm forks. Geometric navel gazing... 😉 Is it warrantied to 160mm forks?
I spent a while sussing tweaking in my full sus with different pressures and settings front and rear plus three rear axle heights to choose from (Banshee) which affect BB height and angles. I like being able to have a local setting and gnarly uplift setting: A bit steeper and taller suits more twisty and pedally trails whilst lower and slacker suits point it down the hill and hold on trails.
Posted : 15/08/2014 11:18 pm
TurnerGuy - Member
Sure I've seen him round Swinley.
Posted : 16/08/2014 12:03 am
I will be interested to have a doodle in linkage to see what the graphs look like.
graphs look good.
thumbsup.
Posted : 16/08/2014 9:36 am
Thanks Brant 🙂 I will send you the real deal when I get back home (currently sat in a field... that has wifi 😮 )
Posted : 17/08/2014 8:34 am
The instant centre migration looks to be very clever 🙂
Posted : 17/08/2014 9:18 am
The FS looks really really nice, might look into em if/when I come into enough money.
Posted : 17/08/2014 9:41 am
Right. I just need to be convinced they can be set up to be poppy.
I haven't liked the Specialized FSRs I've tried because they soaked up too much energy for getting air of small trail features. Conversely, the Cotic Rocket was very lively in the same situations.
I'm hopeful that the high pivot point and progressive rate might help.
Obviously a test ride would be ideal.
Posted : 17/08/2014 10:26 am
This is not good. I was happy moving back to hard tails. Then I wished I'd bought a bird hard tail. Now I'm loving the look of the FS. Bums.
I might end up with a flock in a year or two.
Posted : 17/08/2014 12:24 pm
you would hope that, being a Bird, it would take flight easily...
Posted : 17/08/2014 1:04 pm
Thought I'd just chuck a few photos from around the web here, so that they're all in one place:
Posted : 18/08/2014 6:07 pm
Me likey looky.
Posted : 18/08/2014 6:28 pm
Looks like the Aeris rides good too, What Mountain Bike liked it: [url= https://twitter.com/Bird650b/status/514330275820871680/photo/1 ]https://twitter.com/Bird650b/status/514330275820871680/photo/1[/url]
Posted : 23/09/2014 2:50 pm
Doing a frame only option for less than 900, bit of a challenger for the 650b codeine me thinks.
Posted : 23/09/2014 4:36 pm
Those fs are a bit much for the plethora of swinley locals that are lapping them up.
Geo/suspension definitely sounds good for an enduro race machine mind.
Posted : 23/09/2014 4:47 pm
Was liking the look if these Bird hardtails the other week, then this full suss pops up, looks good, like what these guys are doing. We need more British manufacturers like this. 😀
Posted : 23/09/2014 4:55 pm
Do we know where the Bird frames are made yet?
Might be a toss up between Birds or on one, of which I am suspicious of because the frames are cheeply priced.
Posted : 23/09/2014 4:56 pm
Bird are Taiwan at the moment.
Posted : 23/09/2014 5:03 pm
Cheers AlexSimon 🙂
Posted : 23/09/2014 5:09 pm
AlexSimon - Member
Like most bikes, including Santa Cruz. Same factory even I think.
Nothing wrong with their frames. The price just reflects lower margins or lower business costs. The 456 models of various forms are some of the toughest frames about. Though nothing is indestructible.
Posted : 23/09/2014 5:24 pm
Swinley has a small rock garden and some roots have been spotted recently...
It's the only rock garden in the world to correctly use the singular of the word rock too!*
Depends how it rides, if it's light/efficient enough it'll be fine for Swinley, I wasn't much slower on my Pitch Vs a similar hardtail, it just felt dull on bits like Stickler which are all about sprinting out of and between corners and the rest just felt like a very long transition between the really good bits (15, labrynth, the penultimate blue bit) which are another level of fun on a big FS bike.
I'd be seriously tempted if they can do a good full build at a decent price i.e. that photo/build fo codein money or less.
*As a footnotw, I reckon 15 would be improved if they got rid of one of the small lips before the tabletop on 15 and put a load of rubble down to make a rock garden, it's step enough to make it look intimidating, and fast enough to make it easy to 'float' over one. IME I always used to overcook the penultimate lip (where it kinda kinks left before the RH berm that fires you towards the tabletop) and to my shame cut the corner (which in an off camber, dusty drifty kinda way, was a lot more fun).
Posted : 23/09/2014 5:40 pm
There's a full price list and spec sheet on their Facebook page.
Direct link here:
The shop itself is a little less complete.
No doubting the value and quality of the kit.
It looks from the shop page that it's a £850 deposit with full payment due end Oct, then delivery end Feb/early Mar.
Posted : 23/09/2014 5:45 pm
a rock garden would not go down well with the runners that insist of running up the trails, or the families and dog walkers that seem to often be on them.
the bike trails are clearly not bike specific and it probably wont be long until the first huge accident occurs.
Posted : 23/09/2014 5:47 pm
Under the rules of the estate, they're only allowed to use materials sourced from the forest.
That said there is a spare rock sat beside another trail just waiting to be used.
As for roots... god forbid! 😮
Still, the cobbles on the yellow brick road are quite harsh. Need suspension for that 😉
Posted : 24/09/2014 12:53 am
Break up the concreet inn the pillboxes/tanktraps?
Thing is, rocks are probably the only surface that's better for bikes than any other mode. Just about every other obstacle you could put at the trail entrance would be more of a hindrance to bikes than walkers or horses.
Although TBF some of the cyclists do no favours. I got shouted at by a lady on a very nice bike in a group of others on nice bikes (so given the benifit of the doubt, should know better) for barging past on 15. The fact I was airborne and she'd just hauled her brakes on and stopped right on top of the tabletop seemed to escape her.
Posted : 24/09/2014 10:35 am
Could do with a better brand name than Bird IMO! Give it some attitude.
Posted : 24/09/2014 10:56 am
The official spec list looks spot on! Would be nice to know the price of upgrades/downgrades.
I saw a chap outside the Food Co in Colchester with a Bird T-shirt on. Was going to stop and ask about it but he was with family. I assume it was one of the owners as it's a bit early for fanboys.
Posted : 24/09/2014 11:27 am
I'm suspect the Aeris isn't really designed as a Swinley bike, but I'm sure it'll do the job admirably for the one bike quiver rider.
Anyone know what the frame weight is?
I've been looking at 650b boingy bikes recently and am a tad torn between fronting up for a carbon frame or buying aluminium (like this) and spending the grand+ saving on good parts - any opinions?
Posted : 24/09/2014 12:23 pm
[quote=mattjg]Anyone know what the frame weight is?
I seem to recall reading somewhere that the frame weight for a large, without shock, was about 7lbs.
Posted : 24/09/2014 1:33 pm
Page 2 / 3
