Seatpost shim on Bi...
[Closed] Seatpost shim on Bird Aether 7
 Gunz
I'm about to buy an Aether 7 frame and transfer over the kit from my hard tail. However, my Reverb would need a shim to fit the Bird. I asked Ben at Bird and he said they don't recommend it. Does STW think this is a bit too cautious (I'll be getting the longest shim I can find) or should I bite the bullet and buy a new post (I'm on a bit of a tight budget).
Posted : 01/01/2021 7:50 pm
Sell your Reverb and buy a Brand-X? Probably wouldn’t lose money, wouldn’t lose functionality either (although upgrading the lever is widely recommended)
Posted : 01/01/2021 8:31 pm
I'm running a USE shim on my Aeris145, 30.9 to 31.6. I've not had any issues
Posted : 01/01/2021 8:34 pm
Wouldn’t have thought a decent fitting long shim would be an issue. That said if your reverb currently works then as suggested above you could probably sell it and mostly find a new brand x post. The Aether has a very short seat tube so you can run a long dropper. I’m on a medium at 5’9 and am running a Oneup 210mm post at 200mm drop. I couldn’t quite get it in far enough to run the full 210mm unfortunately!
Posted : 01/01/2021 10:44 pm
I've been using shims for 20 years or so, never had a problem. Giant used to supply a lot of bikes with a 30.9 seattube shimmed down for a 27.2 seatpost. You want a shim that is at least 3" long, preferably 4", and you want it to extend below the seat tube-top tube junction so you aren't putting a lot of stress on the welds there.
Manufacturers will automatically say no to any question like that for legal reasons - they can then reject warranty claims if anything goes bad. It's not based on any engineering considerations, just the legally safest thing to do.
Posted : 02/01/2021 3:40 am
 Gunz
Thanks for the answers, I'm veering towards a shim for financial and 'I can't be bothered to sell the Reverb' reasons.
Posted : 02/01/2021 8:20 am
As long as the shim is a similar length to the minimum post insertion (usually around 10cm) or longer, then there really isn't a problem.
Posted : 02/01/2021 9:48 am
