Seat post clamp bol...
[Closed] Seat post clamp bolt - opposite side to slot?
I've lways put my seat clamp bolt on the same side of the slot, mainly to keep the bolt out of the way pf spray from the back wheel. But I see a lot of bikes with clamp bolt opposite side to the seatpost slot
Which way is yours?
Posted : 19/07/2016 5:54 pm
Opposite because it squeezes the seat tube more evenly and is less prone to ovalising it. Solved my slipping 27.2mm Gravity Dropper problem years ago and I've seen no reason to revert to the normal way round on subsequent bikes!
Posted : 19/07/2016 8:04 pm
my current one is rear facing...in line with the slot
i keep meaning to turn the clamp around but always forget
Posted : 20/07/2016 11:32 am
One of those things I always have the bolt facing away from the wheel
Posted : 20/07/2016 11:39 am
Bolt facing forward!
Posted : 20/07/2016 11:43 am
At 37.2 degrees, widdershins.
Posted : 20/07/2016 11:51 am
Bolt same side as slot - though slot is at front on one of my bikes.
Posted : 20/07/2016 11:54 am
I was told by a couple of different LBS's that you shouldn't align the slot with the gap in the clamp as it produces an uneven pressure.
Posted : 20/07/2016 11:56 am
pretty sure the NP Mega has the bolt on the opposite side to the slot, the PA on the same side
both to the front, away from the wheel and the aestheticly better with a qr.
Posted : 20/07/2016 12:00 pm
The seatpost, and hence collar, on my Giant Defy road bike are aero shaped, which means it can only go together in one direction - bolts to the rear, aligned with the gap.
Think my Cube MTB is the other way around though (and must have been like that when new).
So in summary, Giant and Cube obviously have different views on the subject!
Posted : 20/07/2016 1:09 pm
