Sealing cable enrty...
[Closed] Sealing cable enrty points....frame full of water?!!!
I'm continually getting loads of water filling up the lower part of the frame when,washing/riding the Carbine.
The culprit appears to be the hole where the dropper cable enters the downtube just above the BB.
Any neat ideas for sealing around the cable at this point?
Posted : 01/12/2015 9:03 am
 lerk
Accept that water will get in and drill a drain hole in the bb shell instead...
Posted : 01/12/2015 9:06 am
clear silicone sealant.
Most of my frames seem to fill up with water getting in around the seatpost over time.
Posted : 01/12/2015 9:09 am
Better to let it out rather than try and keep it out
Posted : 01/12/2015 9:46 am
Absolutely. What do you think are you chances of getting the frame completely dry inside, then sealing it up. Sealing up so effectively that it remains sealed and dry after hosings, river crossings, charging through puddles and the off jet-wash? Zero? correct. Best have a drain hole.
Funnily enough, my Californian-designed frame doesn't have a drain hole in from the factory, either ๐Ÿ™„
Posted : 01/12/2015 9:52 am
Ok, so this "drill a drain hole" scared the shizzle out of me.....
What size; exactly where; and warranty issues??????
Any tips would be greatly appreciated.
Hides in corner, with telephone directory over head, waiting for MTFU bombardment.
Posted : 01/12/2015 10:03 am
Bottom of the BB, ie: underneath so the water can fall out*, 4-5mm should do it, and yes it will probably technically void your warranty.
*Not 100% clear from your OP if you mean water is settling in the BB area, or in the bottom of the downtube. have a look in there, if water in the downtube can freely flow to the bottom of the BB then you're OK with the above, but if there are any steps/lips etc that would prevent the water getting to the bottom of the BB shell then you may have to get creative.
If it was [b][i]my [/i][/b]frame I'd do it, but I'm not going to recommend someone to void their warranty and drill holes in a frame if you're not comforatble doing it. Silicone sealant, rubber gaskets and regular inspection and maintenance are your other option.
Posted : 01/12/2015 11:14 am
Or just store the bike hung up somewhere. I get a fair bit of water draining out of my seat tube when i hang my bike up on the wall.
Posted : 01/12/2015 11:18 am
Sugru
Carbine is a carbon frame yeah?
I'd just remove seatpost and store upside down every other ride.
Used to do that with Zestys.
Posted : 01/12/2015 11:20 am
When I emailed Pivot about the same, they said i could drill a hole in the BB shell, about the size of a spoke...
yet to muster the courage to do that, storing the bike upside down instead.....
Posted : 01/12/2015 11:24 am
I wouldn't drill a hole
After cleaning pick the bike up and turn it completely on all axis
Wherever the water got in.. it will soon come out
Posted : 01/12/2015 11:31 am
