SCOTT Spark 24, Upg...
[Closed] SCOTT Spark 24, Upgrade Air Shock
Hello all...
I've just bought a SCOTT Spark for by son, it's a Spark 24 (24" wheels..)The rear shock is like a pogo stick but I've notices some people have fitted air shocks?
Does anyone know where I can get one? I've been onto Scott which was a waste of time (chocolate fire guard springs to mind!!!)
The shock length between centres is 125mm which is pretty dam small...
Thanks in advance, Simon
Posted : 26/02/2016 8:27 am
125mm is tiny. There are shocks about that small, but air shocks that small are likely to be custom or special orders, so unlikely to be cheap. Have you had a look at this thread? http://singletrackworld.com/forum/topic/build-report-custom-scott-spark-20-junior
Smurf ended up with a Risse Racing shock via J Tech. Risse seem to be shock providers of choice to weirdier applications like velomobiles and the like too, for similar eye-to-eye lengths. You might get a bit of leeway with the length through careful use of offset bushings.
I did spot this on eBay: http://www.ebay.co.uk/itm/SHIMANO-Di2-COMPUTER-CONTROLLED-SUSPENSION-SHOCK-UNIT-RS-C810-25-NEXAVE-C810-/182033633895?hash=item2a620cd267:g:Jo4AAOSwBahUz5qt
Might be cheap enough to give it a whirl?
Posted : 26/02/2016 11:36 am
Thanks for reply Jonathan, very much appreciated!!
I'll check out what you've found...thanks again.....
Posted : 26/02/2016 1:26 pm
