Scott scale 29er re...
[Closed] Scott scale 29er rear hub sizing....
 DT78
[#5626418]
Been googling specs and can't find the info anywhere, does the 2013 scale 29er take a standard 135 or is it a newer 142?
Anyone?
Posted : 22/10/2013 8:36 pm
 DT78
Anyone?
Posted : 23/10/2013 12:07 pm
It appears the Spark and Scale both have [url= http://www.scott-sports.com/us/en/technology/bike/IDS_SL_Dropout_System/ ]IDS dropouts[/url], so it could be either.
Posted : 23/10/2013 12:49 pm
Got a ruler?
I've seen one with 135mm but no idea if its the same bike as yours.
Posted : 23/10/2013 12:59 pm
 DT78
Yep if I can't find the info on the net (you would have thought you could) I'll dig it out of the shed remove the wheel and measure the dropout. Hopefully it will be easy to see if there is 7mm difference with a ruler...
It's currently fitted with a Q/R so I think that means it must be a 135/10 ? (scale 920)
So many standards.
Posted : 23/10/2013 1:04 pm
I'm pretty sure this one was a dt swiss hub and QR,
135mm width with a solid 10mm axle, rather than flanges on the hub. So it would also take any standard 135mm rear hub.
Posted : 23/10/2013 1:07 pm
