Hi Guys
I am looking to run the combination of a Nobby Nic 2.4 front and a Racing Ralph 2.4 on the rear, I was wondering if anybody who is running one of these tyres could measure the height and width please?
I am hoping that these are pretty high volume tyres!
Thanks
Adam
What rims?
On 5.1's a NN 2.4 is coming at 50mm tall and 54mm wide.
Thanks Guys! I am running 5.1's, I know rim width would make a slight difference, but overall I should atleast be able to get an idea.
I am just worried that a 2.4RR could end up wider than a 2.4NN which i would not really want, but I do want the volume!
On a 19mm rim a 2.4 Nic is a big old tyre, certainly not undersized by any means. Have also run them on 25mm rims they are just massive.
Unless you have good reason to do otherwise I would put a 2.25 Ralph on the back
2.4 NN is pretty much a 2.4- schwalbe sizes seem to be mostly accurate. Haven't had a 2.4 RR though.
Once again, Thanks guys.
Rocketman; My reasoning behind the 2.4 RR on the rear is a large volume tyre to try and improve the comfort of my hardtail a bit, yet the tread pattern should ensure that it is still a fairly quick tyre.
If anybody is able to measure a 2.4RR It would be very helpful in my decisions.
Thanks
Adam
ill resurect this post as its on the same subject as my question.
ive just ordered a 2.4 nobby nic snakeskin and a 2.2 black chilli rubber queen. my intention was to put the nic on the rear and the RQ on the front. my rims are pretty wide 32mm (outside).
do you reckon the RQ will come up bigger still even though there 2.2 ?
i dont want the back end higher than the front. they will be tubeless also.
cheers guys
