Schoolboy error...l...
[Closed] Schoolboy error...lesson learned!
Swapped my tyres back from 30mm CX from the weekend to 35mm touring type for my commute.
But I didn't remember to swap the tubes, or the spares in my seat pack.
28-32mm tubes do not being used in 35mm tyres. 3 blowouts on the way home from work tonight!
I thought the spare tube I put in after the first blowout looked a bit thin.
Never realised 3mm would be so important.
Lesson learned.
Posted : 30/10/2012 10:30 pm
I don't think it can make that much difference. I may be wrong but I'd check everything. Especially the rimtape.
Posted : 30/10/2012 10:32 pm
I run 26" tubes in my 29er with no probs
Posted : 30/10/2012 10:36 pm
it's because its gone dark all of a sudden. You probably ran over a hedgehog.
Posted : 30/10/2012 10:51 pm
No way was that the tubes.
Posted : 30/10/2012 11:07 pm
Aye, no way was that the tubes.
Posted : 30/10/2012 11:09 pm
 cozz
yeah , as others said, shouldn't be the tubes
I run 2.5's in a 3.8 !
Posted : 30/10/2012 11:11 pm
Yep....update....just checked thoroughly in the daylight.
Rear tyre had split at the bead! Tried with a new tube this morning (in nice bright daylight) and it bulged out of the tyre. Was clearly pinch flatting against the rim.
Didn't think it could be the tube. Ruined a nice night time commute too, as it wasn't wet or particularly cold, which was fortunate. And at least it happened on a road section, so the missis could drive out to rescue her forlorn sad faced old man.
So, what 700c tyre for 25 mile each way on/off road commute? ๐Ÿ˜‰
Posted : 31/10/2012 10:57 am
conti gators?
Posted : 31/10/2012 11:38 am
Conti 4 Seasons.
Posted : 31/10/2012 11:42 am
Hmmm...not sure about those two. Maybe a bit too road focussed?
About half my commute is country lanes, tarmac cycle paths, and a couple of miles of city road.
The other half is farm track, cinder, towpath, bridleway, field edge track etc. Odd bit of mud, but not long enough to factor in, and if it's been wet I detour to avoid that so I don't turn up to work covered in mud and leave a trail through the office to the showers!
Carrying 10kg in panniers too.
Current tyres have been Michelin Trekker, but I've now lost confidence in them ๐Ÿ™
I have tried it on some borrowed 28mm Luganos, and it was very skittish on the off road sections.
I can only get 30mm tyres in without having to deflate the rear to get it in! So 28 - 30s needed.
Posted : 31/10/2012 12:09 pm
Schwalbe Marathon. I've been touring on them all year and that's included all the surfaces you've mentioned. They'll not handle mud that well - OK if you have the momentum to blast over a short section but no grip as such - everything else is just fine.
The standard Marathon is reasonably puncture resistant, the Plus version is really heavy and a bit more "dead" to ride but almost bombproof.
Posted : 31/10/2012 12:13 pm
Schwalbe Marathon+ +1
great tyre, not the quickest at all and not great in mud as Druid says but great for everything else you've mentioned
I've not had a single puncture with them in nearly 2 years of commuting 14 miles nearly every day of the week
Posted : 31/10/2012 12:19 pm
Another vote for Schwalbe Marathons here. Alternatively, Schwalbe CX Comps - 30c, and roll well enough on tarmac.
Posted : 31/10/2012 12:23 pm
Looks like a Marathon Greenguard 28c. Got to order some other bits from CRC anyway, unless there are any super cheaps about?
I note that the CRC description shows this with a weight limit of 85kg. I'm 84kg kitted up, plus 10kg in the panniers, plus I reckon the bike weighs 10kg. So that's 105kg.
Any thoughts? I don't normally 4rse about, but don't want a repeat splitting tyre as we edge into winter!
Posted : 31/10/2012 12:48 pm
Weight limits on tyres? I can't say I've ever noticed such a thing before. In any case, they are pretty robust.
10kg in your panniers - what on earth are you carrying. Coal?
Posted : 31/10/2012 12:56 pm
Panaracer pasela. Good puncture proofing, fairly light and decent rolling resistance.
Posted : 31/10/2012 12:58 pm
@ druidh - haha! Nah, I'm a homeworker but go to the office once a week. So I have to carry clothes, shoes, towel and toiletries, laptop and gubbins, notebooks/files etc!
No chance to leave anything at the office either!
Good training though, especially on the hills!
Will be ordering the Marathon shortly.
Thanks for the info folks.
Posted : 31/10/2012 1:04 pm
+1, very odd, I'd not worry
Posted : 31/10/2012 1:42 pm
Check it's not your brake pads having uneven wear (over the top of the rim). Thats what caused a split near my bead and subsequently lots of burst tyres. Took me a while to figure out. Badly set up brake pads basically.
Posted : 31/10/2012 1:45 pm
Cheers BenjiM. I gave the rims a good check this morning when I found the split tyre.
They look good, but will give them another check over later after work....if the trick or treaters finish early enough that is!
EDIT: Although re-reading you might be referring to the brake oad rubbing the tyre. Will check that too.
Posted : 31/10/2012 1:50 pm
Correct ๐Ÿ™‚
Posted : 31/10/2012 1:56 pm
yeah brake pad on the Tyre I had one do that a few years ago, it went with one hell of a bang
Posted : 31/10/2012 2:45 pm
never seen this for a bike (although you can buy tandem rated tyres) but in a car you'd divide it by wheels, so your 105 kg becomes 52.5 kg.
Posted : 31/10/2012 2:50 pm
Ordered the Marathon Greenguard in 28mm. I did wonder about the weight, and figured some would be distributed to the front, but still lots at the back with me perched on it and loaded panniers.
Will see how we go.
Deffo not brake pad rub. Just the sidewall pulled away from the bead. No scuffing at all, and just checked the pad contact with a temporary 35mm tyre fitted, and clears the tyre fully
Posted : 31/10/2012 6:18 pm
I always carry a piece of damp-proof course in my bag as a patch for split tyres, takes virtually no space, and has saved many a ride(obviously depends on you recognising you have a split).Been carrying mine since the whole Panaracer Smoke re-issue farce of many years back.
Posted : 01/11/2012 8:51 am
Schwalbe Landcruiser.
Posted : 01/11/2012 9:25 am
Conti Country Ride
Posted : 01/11/2012 11:01 am
