Scandal 26 or 29 as...
[Closed] Scandal 26 or 29 as a single speed.........any reason why not?
 SiB
Was going to press buy on the in bred 26er or 29er slot drop out as want to run ss with a possibility of gearing in the future but now tempted by the scandal 26 er or 29er............any reason why it would be a bad idea to but the scandal for a ss.
Want to take advantage of on one sale before it finishes!
Posted : 27/12/2012 11:11 pm
 nuke
Go for it. Scandal will make a great SS bike but you'll need to get SS dropouts as they don't come with them.
Posted : 27/12/2012 11:22 pm
None. Depending on the size it will be much lighter. Mine rides superbly.
Posted : 27/12/2012 11:26 pm
 SiB
Thanks nuke, do you work for on-one!!?
Two quick questions before I buy a scandal....have i read somewhere that ss dropouts are £30? And finally...are both the 26 and 29er ok to run as single speeds, any problems with either?
Posted : 27/12/2012 11:29 pm
 nuke
[i]Thanks nuke, do you work for on-one!!?[/i]
😀 Nope but I do have a very nice Scandal 29er (the raw does look great...kind of pre-worn)
Think Brant said on the [url= http://singletrackworld.com/forum/topic/psa-cheap-on-ones ]O-O sale thread[/url] that you might need to do a bit of filing of the swapouts but nothing major 😕
Posted : 27/12/2012 11:32 pm
They were £30 for the SS dropouts and mine (29er) did not need filing to fit. The DMR chain lugs however...
Posted : 27/12/2012 11:35 pm
I've got a geared and a ss one, very happy with both. had to file my dropouts (I posted a pic of the filed dropout on here a while ago) but I think it's maybe just a v2 issue
Posted : 27/12/2012 11:40 pm
Ran reverse spring tensioner on vert dropouts for years no issue. That's the beauty of ss...cheap biking!
Posted : 28/12/2012 12:05 am
Other than it being a bit like buying a colour TV and turning the colour and contrast down so it looks like a black and white, go for it.
Posted : 28/12/2012 12:30 am
Isn't the 26er one vertical dropout only, without the swap out? So can only be run geared..
Posted : 28/12/2012 1:33 am
26er may be vertical dropouts only, but that doesn't necessarily mean geared only. I chose the vertical dropout Inbred for my SS, as I prefer a tensioner (instead of tugs): fixed position brake calliper, adjusts for chain wear automatically, easy to get the wheel in/out for transporting in the boot.
A Surly Singulator and a half link worked well for me.
Posted : 28/12/2012 8:21 am
buy a 26", add a 29" front wheel for a niche not many follow
Posted : 28/12/2012 8:30 am
