SC Nomad - Talas 24...
[Closed] SC Nomad - Talas 24's or Talsa 36's
Question 1 of 2
Pretty much decided to invest in a Carbon Nomad as an all mountain / xc bike. Will be used out here in OZ as a trail bike - more xc than anything and as my main bike when I come back to visit the UK. It might see some use in Queenstown in NZ when I head over again so I can ride a bit of everything. In the uk it will be Local xc / trails centers and a bit of DH - Ribbesford / Cannock / FOD etc so nothing too crazy. I have a V10 for the proper DH stuff uplifts / alps / racing etc which I can always bring back if need be.
So Fox 160mm Talas 34's or 36's? on the front? Had a set of 36RC2's before and I did like them - they were set up ok - but I don't really think I need that much adjustment really.
Will the 34's with 15mm axle handle the DH ok?
What is the CTD like to live with - do you find you stick it in trail and leave it there pretty much?
Can you get a remote for the 34's - which would actually make the CTD Useful?
Cheers.
Posted : 28/09/2012 3:47 am
The missus has just ordered the Blur LTc out here and Talas has dropped off the spec list - getting one sourced but not sure how long they will be available as standard.
[url= http://www.pinkbike.com/news/fox-suspension-2013-float-ctd-first-ride.html ]Pinkbike Says[/url] 90% of time in T mode on the shock/fork
When I demoed the nomad I found it to be well balanced and not really needing a drop at the front to climb.
On the 15mm probably good for the lighter rider but 20mm for the harder/heavier rider.
On a serious note don't discount the Blur LTc was as capable in a lot of ways. I wanted a Nomad but probably should get a blur 🙂
Posted : 28/09/2012 5:06 am
I wouldn't bother with a Talas fork on a Nomad. I've run mine at 160 & never felt the need to lower the front for climbing.
Posted : 28/09/2012 8:50 am
weight wise there's almost nothing between the Carbon Blur and Nomad though, although they do ride quite differently. Blur feels a bit faster, stiffer (we're talking fine margins here) but the Nomad does feel a nit plusher. FWIW I love my Blur LTc though.
Anyway back to the question, You would be fine with 34's, in fact that's probably what I would spec as they're a good compromise between stiffness and weight. £^'s are amazing, but a bit overkill for a trail bike IMO. Wouldn't worry about the stiffness of 15mm axles, mine has it and I don't notice any flex and I've just come back from 8 days riding in the French Alps.
Posted : 28/09/2012 8:51 am
Wouldn't bother with fox IMHO, RS lyriks are on mine and they are fab. Had 36 vans before that which were good as well but had usual fox longevity problems. If I was going fox I fero would not go talas, you will never need it. T
Posted : 28/09/2012 10:34 am
Did consider Lyrics however I have had fox 36 before and like the feel and I have recently gone from boxxers to 40's on the V10 and much prefer the feel of them too.
Will likely go for the 34 Talas CTD I think - means I can just buy a set of alloy Havens and be done with it rather than trying to convert wheels back and forth.
If I really want to ride full on DH then I'll have to get the V10 out. Can't see me hiting anything local that would be too much for 34's/nomad/ haven components / wheels.
Posted : 28/09/2012 3:31 pm
