Sapim Laser spokes ...
[Closed] Sapim Laser spokes - too light for mountain biking?
[#6481112]
I was thinking of pushing the boundaries of lightweight wheels without spending a fortune. I can get a 740g front wheel built using Sapim Laser spokes and alloy nipples for about a ton.
Any thoughts?
Posted : 13/09/2014 6:31 pm
you probably know they're not recommended for disc wheel use but Shona uses them for her 'race' 29er and they've been fine - she's only little though...
Posted : 13/09/2014 8:39 pm
Alloy nipples up here in Aberdeen that too would be a bold decision.
Posted : 13/09/2014 8:42 pm
Oh yes missed that, alloy nips - just say no!
Posted : 14/09/2014 9:18 am
Sapim D-Lights.15g difference over 1 wheel and designed for disc use.
Posted : 14/09/2014 9:19 am
I'd use them. No lighter than Revolutions, which I use. Never had a problem.
What size, axles etc? If 26" I reckon you could go lighter for not a huge amount more money.
Posted : 14/09/2014 9:20 am
I'm thinking of having a light front wheel built.
Laser spokes, alloy nipples and Crest rims. I can maybe get the weight down to under 680g plus tape and valves. My current front wheel weight is 950g.
Posted : 16/09/2014 4:15 pm
 adsh
If you're light and easy on kit you could also try Podiums
Posted : 16/09/2014 5:00 pm
I've also got Revs on my main (disc) wheels, which as Nick says are pretty much the same. In terms of wheel stiffness and strength they're also the same as CX-Rays, which plenty of people seem happy to use.
Posted : 16/09/2014 5:05 pm
If its for a light rider, on a race bike thats going to be used just for races and not dragged through the mire week after week, and you consider wheels to be 'disposable' after a season or two, then no reason not to.
I had a set of wheels with the skinny DT Swiss spokes (forget which now) and ally nipples - after 2 years of fairly regular fairly hard use, the nipples started splitting and spokes started snapping. Hubs are still in use with new spokes and rims though!
Posted : 16/09/2014 5:13 pm
Whilst I'm not hugely heavy (67kg presently), I had a set of Podium Rims (with Revolutions) for about 3 years, used at various trail centres - Afan, Dalby, Haldon, Brechfa. They stayed nice and true, and the (alu) nips didn't explode. Never broke a spoke.
Too much concern around this sort of thing IMO.
Posted : 16/09/2014 5:16 pm
mocha - Member
Are they not? I know they're not marked as approved for disc on the website, but then most of their other spokes aren't either (cx-rays frinstance), is there another thing?
Am I right- is the Laser the one that's just an unsquashed cx-ray?
Posted : 16/09/2014 6:27 pm
Yep.
Posted : 16/09/2014 7:41 pm
Dead on 740g!
Superstar Ultra front hub, Sapim lasers, Crest rim, Red alloy nips. £140 shipped.
I have red alloy valves to fit as well.
Now for the rear. I want a 12x142mm hub that is light and has a quiet freehub ratchet - any suggestions? I will build using Crest rim and alloy nips but with Sapim Race spokes instead (unless anyone can reassure me that lasers are just as strong?). I tend to be heavier on my rear wheel.
Posted : 24/09/2014 1:37 pm
They're not as strong, but they're strong enough for most.
Re hub, American Classic? Try AEBike.com for more reasonable pricing than the UK.
Posted : 24/09/2014 1:57 pm
I've got them on my 5. I've ridden them all over the place, including lots of rocks and mountains, without mincing, for 7 years, and I've been on average 89kg for most of that time. Never had to true them once.
Posted : 24/09/2014 2:01 pm
I just weighed the wheel without the standard Superstar rim tape. 700g! That rimtape is heavy!
Posted : 24/09/2014 4:16 pm
