Santa Cruz, Loctite...
[Closed] Santa Cruz, Loctite 680, Bearings
I'm about to change the bearings on my 07 heckler and the instructions state that loctite 680 should be used. It looks like this is extremely difficult to get hold of in the UK.
I have emailed Santa Cruz and checked out the MTBR santa cruz forum without success (as yet)
Have loctite changed the number? Does anyone know of a shop or site in the UK that has 680?
Posted : 19/07/2010 10:45 am
If you get the replacement bearings from Stif cycles you get the Loctite free in with the bearing kit.
If you wantsome I have a spare tube and could post it to you.
Don't know what the loctite number is but it came supplied with the bearings for my Blur LT.
Hope this helps!
Posted : 19/07/2010 10:53 am
I ordered my bearings direct from Jungle. No loctite.
munchiepumps I'll send you an email.
Ah - no email in profile.
phil ATTTTT unsponsored DOTTTT co DOTTTT.uk is mine. I'll take you up on your kind offer.
Posted : 19/07/2010 10:55 am
680 isn't listed on the [url= http://www.loctite.co.uk/cps/rde/xchg/henkel_uke/hs.xsl/fullproduct-list-loctite-4995.htm?&countryCode=uke&BU=industrial&parentredDotUID=productfinder&redDotUID=productfinder&param2=mode%3Dfull| ]Loctite site[/url] anymore.
Try phone them on +44 1442 278000 and see what the closest alternative is?
Posted : 19/07/2010 10:58 am
 tf
You can't get the 680 in the UK, it's some kind of a US specific number, but you can get other bearing retention loctite stuff instead -- they make a shedload of different compounds, and it is not really clear which one of them is equivalent to the 680, but I ended up going for 641. However, as munchiepumps said, you will get small amount of 680 with the SC bearing kit.
Posted : 19/07/2010 11:00 am
Just spoke to Loctite UK. 680 is USA only. 638 is the UK version.
Posted : 19/07/2010 11:18 am
I have sent you an e-mail so you can send me your address.
Posted : 19/07/2010 11:19 am
Thanks. Have emailed my address.
Posted : 19/07/2010 11:28 am
yep 638 is the stuff you need.....
Posted : 19/07/2010 12:35 pm
