Santa Cruz grease d...
[Closed] Santa Cruz grease discontinued - original gun, any recommendations?
Need to regrease the lower VPP links, couldn't find the grease on sale, emailed jungle
I am sorry but the Santa Cruz grease is not available on its own ( without the gun) but any quality grease is all you need. I think finish line do a tube that fits.
Hope this helps"
I'm after a tube of this, or a tube of grease that has same thread fitting... any ideas?
Ps. I also have the Hilka grease gun which takes cartridges but last time I used it blew the seals out of bearings, so would prefer to stick to the lower pressure SC gun.
Posted : 03/06/2017 10:15 am
I'm sure I read somewhere that it's just rebadged super lube.
Same as the stuff I US on Turner bushes so I know it fits the grease gun.
Other option is the full dulco gun and fit that nozzle and grease of your choice (maxims or silkolene if it sees a lot if wet use).
Posted : 03/06/2017 10:22 am
The Hilka is the original SC grease gun or very similar to the old one shipped with Nomad Mk2 http://forums.mtbr.com/santa-cruz/sc-grease-gun-cartridges-other-options-927115.html#post11437565
The newer one looked cheap and a faff to me.
Anyway the older SC one I used to moan about but for some reason it's working quite well now. Never blown out seals with it. With that (and Hilka I'd assume) you can just vacuum fill from a tub of grease. I got a tub of marine grease and just fill the gun with empty old cartridge still inside. Shove one end into the grease, pull up handle, repeat couple more times. Job done.
Posted : 03/06/2017 10:32 am
Cheers guys,
Tried the hilka several times and always gives blown seals and VPP strip down, so quite keen to get the newer rubbish screw in grease tube one going again which works great but does require squeezing the grease tube when pressing the lever.
I've just found this and wonder if its the one Jungle refer to, looks the same size tube as SC, and reviews say thread fits most grease guns
http://www.wiggle.co.uk/finish-line-ceramic-grease-60gtube/
Amazes me SC have stopped supplying it with the VPP zerk ports on all their new bike range, and sales booming 🙁
Posted : 03/06/2017 10:36 am
Use Lucas Red Tacky marine grease and the Hilka gun - works ok for me.
Not sure how you can blow seals with this as the lower link seals are open anyway and designed to allow grease through them. You do need to be a little careful not to apply too much pressure, bit otherwise it's fine.
Posted : 03/06/2017 11:48 am
Mobil xhp222 is about the best bearing grease around.
Posted : 03/06/2017 12:07 pm
https://www.amazon.co.uk/d/Lubricants/Super-Lube-Synthetic-Grease-Syncolon-Multi-Purpose/B000XBH9HI
Very good grease, it's been lashed into the wife's 5010 and all our Chris King bearings with no issue at all (the bottom brackets are still as good as new with a regular flush of superlube).
The tube will also screw straight into that little grease gun from Santa Cruz
Posted : 03/06/2017 1:56 pm
Thanks, bramble i've ordered some of that purely as its confirmed as working in newer gun 😀 Cheers!
Posted : 05/06/2017 7:44 pm
Eek, £7.50 for 90ml!!!
I only paid £9 posted for the 400g of Mobil grease that Nobeer mentioned. Will fill that Hilka gun of yours many times over. Been using for a few regreases with no issues. Same stuff Hope use (sparingly, grrr) when assembling their stuff.
Posted : 05/06/2017 8:01 pm
Bookmarking
Posted : 05/06/2017 8:25 pm
+1 for Mobil XHP222. It's great quality and has the added bonus of being very versatile. I use it for all bearings and some suspension duties (Fox recommend it too).
I think a lot of the Santa Cruz grease gun problems come from the fact that SC recommend marine grease in their pivots. Because marine grease is so thick it needs really high pressure to force through the ports and into pivots. The Mobile stuff isn't so thick, so is much more user friendly.
Posted : 05/06/2017 10:30 pm
I use both, and there isn't a huge amount in it. XHP (which vastly superior) is still pretty thick. I think super lube is a fair bit thinner. I still use XHP, I think it's a suitable product for the conditions we ride in.
Posted : 05/06/2017 10:33 pm
Just an update, received the superlube synth and used it yesterday, fits the new gun perfect, lower pressure of newer gun kept seals firmly seated and flushed all the old winter gunk out
I'll report back in a few months, but went in much better than SC original grease which gets a lot of air bubbles and spills over the zerk port instead of going in very easily. Looks decent stuff on the specs.
[img] ?1[/img]
Posted : 12/08/2017 10:16 am
Same stuff I used to use on my Turner Flux and 5Spot. I still have an unopened tube of grease and the gun with the curved nozzle if anyone is interested.
Posted : 12/08/2017 12:48 pm
Exactly, I'm pretty sure santa cruz don't manufacture thier own grease, it'll just be rebranded.
Posted : 12/08/2017 12:53 pm
I have a second hand one somewhere. PM me if you want it. Free barring postage.
Posted : 12/08/2017 6:52 pm
I have the hilka grease gun also, it stuck to the zerk 1st time I used it,
Any tips to ensure it comes off easily next time I use it?
The most suitable grease I could find locally is the Carlube Aquaslip Waterproof Marine grease. Anyone like this?
Posted : 12/08/2017 10:10 pm
Still not sure how you blow the seals off. Never had that happen to me. The seals have a metal outer on the lower link.
As for grease, Marine grease is the best stuff to use. Good thick and waterproof.
Key to avoiding spilling out is to screw onto the grease port and press the gun firmly in place while pumping the grease in.
alric - Member
Exactly what I'm using at the moment. Odd looking brown grease, but does the job fine. Was likewise just what I could find in a local hardware type shop (lot of boats round there so must be what they use for boaty stuff). Tub of it so I fill the old style SC gun from it as I mentioned above (Hilka gun branded Santa Cruz).
Posted : 13/08/2017 10:31 am
that hilka grease gun is supposed to use bulk grease also. On mine the seal just slides through the grease. Am I supposed to put an empty cartridge in it first and then fill it up?
Posted : 13/08/2017 2:19 pm
I left the original cartridge in there and just refilled it each time direct in the gun. Shove it into a tub of grease, pull lever up, repeat a few times until enough grease in there.
Posted : 13/08/2017 2:51 pm
then I guess I have to empty the hilka cartridge first....
it can't be too difficult, I got grease all over everything already, without trying...
Posted : 13/08/2017 3:25 pm
