Santa Cruz blind be...
[Closed] Santa Cruz blind bearing removal
So, it seems stif/jungle are out of stock of the removal tool for the suspension pivot.
I guess the options now revolve around either a pilot bearing puller, or a slide hammer system. Anyone got any recommendation?
Posted : 03/10/2015 3:59 pm
For actual bearing removal....no. The bearings on my Butcher have been serviced in situ by me several times. Dismantle the swingarm/linkage pivots. Remove bearing seals, clean bearings out with Isopropyl alcohol, re-grease & assemble. It's kept them alive for several years without removal.
D.
Posted : 03/10/2015 5:15 pm
I've just the slide hammer type bearing puller on my Blur LTc in the past with no probs.
Same story for me, Stif/Jungle where out of stock of the correct tool at the time.
Posted : 03/10/2015 6:45 pm
 nuke
Could you use the expansion bolt method? Cheap & worked a treat with my Hemlock bearings...i did a guide on [url= http://singletrackworld.com/forum/topic/sooooo-hemlock-owners-any-tips-to-shift-these-bearings ]this thread[/url]
Posted : 03/10/2015 6:57 pm
D.
How do you remove the seals without damaging them?
Or do you fit new seals?
Posted : 04/10/2015 12:41 am
Use a sharp pick, they just lift out. Other than that, a slide hammer works well, I have the official puller but it's quite tosh so bought a hammer anyway.
Posted : 04/10/2015 5:40 am
thanks guys, all useful stuff. Steve, you've just confirmed my suspicions there ๐Ÿ˜‰
Posted : 04/10/2015 9:43 am
Quick revisit. the bearings were seized/buggered anyway, i got a cheap slide hammer system on fleabay and had them out inside of 30 mins. Looking at the tools, i think i'd be happier with the slide hammer anyway, its longer so theres more chance of spotting if a bearing is going off-axis.
Posted : 12/10/2015 9:05 pm
