Right, I'm in the process of building up a 2011 Turner Flux and managed to buy a set of Easton Havens for a very good price. The spec stated 10x 135 rear. When the wheelset arrived, the ID was indeed 10mm so I went looking for a skewer/ bolt to suit. [url= http://www.silverfish-uk.com/ProductDetail/0/16233/QR-R-135MM-E-LOGO-MTN/EA2017040 ]This on the Silverfish[/url] website seemed exactly what I needed and I placed an order. On receipt, it's just an ordinary OD skewer and although it all fits together, there is a clear annulus between the skewer and the hub.
So, having only had old school QR or dedicated bolt through which was supplied with the frame, is this item correct? Is the gap okay, or will I die a horrible death?
DT Swiss do thru axles that fit into standard dropouts, 9mm front and 10 mm rear
[url= http://www.madison.co.uk/products/cycling/tyres-tubes-wheel-components/hub-spares/rws-bolt-thru-rear-10-x-135-mm-aluminium/ ]LINK[/url]
Superstar do an axle as well. Heavier, and in my opinion having tried both, not as secure but much cheaper
http://www.superstarcomponents.com/en/10mm-rear-qr-through-axle.htm
Thanks Hatter. I'd looked at the DT Swiss axle, it's just I've received the Easton Skewer and hoped to finish the build before Christmas. That said, I have doubt in my head so will probably get one anyway before I ride the bike.
That looks like a normal skewer so it's not right. Needs to be bigger or it won't sit properly in the drop out.
Mine's from Superstar.
Jimw,
Out of stock! Which is a real shame as I've seen ordered a narrow wide chainring from SS today.
Shifter,
I thought they had simply used a stock image as the spec states 10x135, but is is just a standard diameter skewer, hence my question on here.
Superstar have got their [url= http://www.superstarcomponents.com/en/ultralight-alloy-10mm-rear-qr-through-axle.htm ] Ultralight[/url] 10mm thru-axles in stock.
those ultralight ones are nearly as light as the DT swiss ones,
Brilliant! The ultralight one is in stock and comes in silver too. Top notch work STW!
CRC advertise the DT Swiss one at 33quid, but alas, not in stock.
should have a DT swiss in garage if you still want one
I've just placed the order with SS for the Superlight bruneep, but thank you for the offer. I would have taken you up on it too.
no worries
Does the 2011 Flux really have thru-axle drop-outs? Isn't it just old school 135x10QR? So the skewer you ordered should be absolutely fine (assuming you have the 135X10 hubs and not the 142x12?).
I think you have a 12x142 hub and a 135x10 frame.
Shandcycles,
Here is the listing on EBay:
[url= http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=221862257351&category=177830&pm=1&ds=0&t=1450647541953 ]Easton Haven[/url]
It states 10x135 and the drop out and ID share the same diameter when I offered them up, but I'll check again tomorrow.
The rear came with an adapter for both 135 and 142 width. They fit the frame with no flex of the rear swingarm.
Do you mean ID? ID is 'inside diameter'. If the OD (outside diameter) of the axle is 10mm and seats into the frame dropout then the skewer you ordered is the correct one (again, assuming the frame is setup for 135x10). Don't get confused between skewer and axle. They do different things. The fit of the skewer you have will be loose through the axle but when under tension, will stop the axle dropping out of the frame. With a thru-axle system the retention device and axle (that runs through the bearings) is the same part. In this system, there is a much closer fit when fitting the axle in the hub.
i bought the same wheels,
i use this, and it bolted up fine in my standard QR dropout frame,
http://www.chainreactioncycles.com/dt-swiss-rws-thru-bolt-alloy/rp-prod81162
Bruneep, pretty sure I'll take the skewer if going and OP has passed on it.
Can you email me some pics and price please?
Thanks.
