I started building up my Vaya this afternoon.
I'm trying to reuse the SKS mudguards I had on another frame. I have about an inch of stay to create a bend to accommodate the front BB7 caliper. Any pictures would be helpful too.
Cheers MC
I used the low rider mounts like you found on mtbr... Seems fine after a couple of months
I just popped up to the shed to check, it looks as though the mounting bracket will foul the pannier hook.
I should be able to bend the stay around the caliper, but I suspect the stay will not be long enough.
Does anyone have a spare set of front uncut mudguard stays?
EDIT - I managed to find them online for a couple of quid each, so I have four goes at getting it right. ๐
Use some of these on my day 1 disc - work really well:
[url= http://www.chainreactioncycles.com/north-shore-billet-fender-mount/rp-prod51309 ]North Shore Billet fender mounts[/url]
No pics but I bent the lower part of the SKS stay (uncut, I had a spare) below the caliper and back up to the guard. It fitted fine. I'm liking that lowrider mounts idea though!
EDIT: actually it's the upper part of the stay. Found a pic but it's not online. Happy to email it to you though.
Can you attach it (NDS) to the upper disk calliper mount?
I fitted the caliper with a stainless stud (cut off bolt) and nut, leaving enough stud to mount the mudgaurd. Also needed to cut and bend the mudgaurd mount (including a dog leg).
If I can work out how to add a photo, I will!
It's not a Vaya but...
... the DC17 forks on my Amazon has fender mounts on the inside at exactly that point. Works a treat.
[url= http://farm7.staticflickr.com/6070/6032054553_ece16ca8cb_z.jp g" target="_blank">http://farm7.staticflickr.com/6070/6032054553_ece16ca8cb_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/druidh2000/6032054553/ ]2010-04-13 23-45-11[/url] by [url= http://www.flickr.com/people/druidh2000/ ]ScotRoutes[/url], on Flickr
I'll throw some pics up when I'm home tomorrow..
Would something like this work
http://www.kinesisbikes.co.uk/pro6-widget/
It does on my pro 6 and I'm fairly certain you could find something in a DIY shed that would serve the purpose
I use mine on the forks of a pompetamine.
I did what druid did.
Before he did it obviously.
On my Norco Indie Drop (similar fork) I had the same issue, just mounted them to the inboard mid-fork eyelets, never had a problem. Also leaves the outer eyelets free to mount the Tara rack.
