saint bash ring
[Closed] saint bash ring
Hi All
I have a few a questions re a Saint bash, i had one given to me, can i:
a) fit to a SLX drive train (i'm aware that i have to remove the outer ring) the hole pitch looks the same?
b) if so, what size bolts do i need?
c) where can i get said bolts?
Nick
Posted : 30/04/2011 6:08 pm
Raceface polybash bolts will fit and cost around £5 from CRC or Wiggle. Doubles aren't normally long enough and you need something around 13mm.
The bashring will fit the holes but you may need to file a bit of plastic off so it fits.
Posted : 30/04/2011 6:24 pm
I though you needed some special washers? My bash ring is sitting unused in the shed because I can't get the washers.
The normal chainring bolts just drop through
Posted : 30/04/2011 7:23 pm
They come with brass insert to stop you crushing the bashring when you fit it but other than that you just need the right length bolts.
Posted : 30/04/2011 7:51 pm
Any idea on part numbers for these washers/spacers? Or anyone know if a spacer from something else will do?
Posted : 10/05/2011 11:38 pm
