Rust on Avid Disc R...
[Closed] Rust on Avid Disc Rotors
[#312002]
Hi,
Anyone got a good method for dealing with rust on disc rotors?
Cheers,
Jon
Posted : 17/02/2009 12:34 am
Gentle low grade emery cloth?
Drying disc after riding in rain.
Ride and use metal pads that will be harsh and clean the disc.
Oh and ignore nayone you tells you chuck oil on to it!
Posted : 17/02/2009 12:35 am
just ride it, but if it's rusting on the spokes of the rotor rather than the braking surface just use wire wool to remove it
Posted : 17/02/2009 12:43 am
Proper rust? or a bit of orange?
If the first, then depending on where on the rotor I'd think about swapping it, if it's the second, then first bit of braking next time out will get rid of it
It's not rust, it's a particularly virulent form of fungus; Rotor Blight. It looks just like rust, but if left untreated, it could spread throughout your bike (even carbon and Ti aren't safe from it's ravages), and ultimately, and very terrifyingly, to your crotch. Whereupon it will metamorphosise into Dreaded Scot Rot. You do not want this happening.
You need to clean it all off, and what you need, is alcohol. A fine Cognac is ideal. Maybe one or two measures to begin with, and more if you feel that you have the capacity for it.
Oh, and use some wire wool and Acetone to clean the discs.
Posted : 17/02/2009 1:24 am
Nice one! A combination of several measures of quality alcohol, some new brakes pads, a bit of diligent cleaning and from now on more attentive drying and jobs a good un!
Many thanks to all suggestions
Posted : 17/02/2009 3:49 pm
Make sure you get it all, or it'll be creeping up your frame, towards your dangly bits...
Posted : 17/02/2009 3:53 pm
Where rudeboy will happily lend a hand lol
Posted : 17/02/2009 10:13 pm
by hand I believe you mean a cramped and sticky begloved appendage?
Posted : 17/02/2009 10:16 pm
Just ride your bike more, you have obviously left it alone too long.
Posted : 17/02/2009 10:19 pm
 duir
Maybe not. I have experienced the same on all my Avid rotors and I ride both my bikes several times a week.
Posted : 18/02/2009 1:29 am
