Running one sintere...
[Closed] Running one sintered and one organic pad in the same caliper?
I was reading an interview with Giant rider Adam Craig where he said that he, along with all the other riders on the Giant team, mix brake pads i.e. run an organic and a sintered pad at each end. Supposedly this gives 'the best of both worlds' with regards to power, squeal etc.
Has anyone tried this? Is this a good idea?
Posted : 24/12/2010 5:45 pm
Wouldnt the organic wear out quicker than the sintered? I've never had a problem with sintered pads, could try superstar kevlar pads if you want best of both worlds?
Posted : 24/12/2010 5:48 pm
Sounds like a bad idea to me.
You'd get different wear rates for the pads
I guess it's another case of race teams throwing resources at a problem an getting tiny increments in Performance for reductions in longevity. Which is not a problem if you are in a team and get all your parts from your sponsor ๐Ÿ˜‰
Posted : 24/12/2010 5:52 pm
Shimano lx brakes I bought years ago advised that. There were two sets of pads in the box.
Posted : 24/12/2010 6:01 pm
I have done in the past, if i remember rightly this was because of the premature failure of a well-known factory-direct-brand of sintered pad. There was certinly a changeover period between the wearing out of the remaining sintered side and its replacement with an organic one again. I can't say I really noticed any difference.
Incidentally, having one part worn and one new pad is the only way I can manage to use ssc/imperial pads in my Oro's as the backing plates are significantly thicker than proper formula pads, and so you can't fit 2 new pads and the disc rotor in the caliper. ๐Ÿ˜•
Posted : 24/12/2010 8:04 pm
you'll go round in circles!!
Posted : 24/12/2010 8:09 pm
I always replace just 1 pad per caliper. Currently got 1 superstar kevlar and 1 superstar sintered at each end. Works a treat.
Posted : 24/12/2010 8:10 pm
you WILL die.
Posted : 24/12/2010 9:15 pm
I put toffos in one side and rolos in the other
Posted : 24/12/2010 9:16 pm
Scotch in one side and Brillo in the other.
Posted : 24/12/2010 9:18 pm
