Running a road cass...
[Closed] Running a road cassette on DH wheels.
So I've got 2 sets of wheels including a bargain set of DeeMax. The DM's are only going to be used for uplift stuff so considering getting a road cassette and spare chain so I can just swap the wheels and chain over when i need to.
Are there any issues running a road cassette on MTB freehubs, anything to take into account?
Posted : 08/05/2015 9:09 am
Nope. Just different ratios
Posted : 08/05/2015 9:14 am
I have run Ultegra cassettes on Hope hubs for ages with no problems at all
Thanks chaps ๐Ÿ™‚
Posted : 08/05/2015 9:16 am
Make sure it's tight, road cassettes tend not to have alloy carriers as they'r esmall, so they can gouge freehubs
Posted : 08/05/2015 9:39 am
I've run road cassettes on my mtb for years, never had any trouble. All good
Posted : 08/05/2015 11:05 am
just remember to faff with the B-tension screw when you switch between the wheels
Posted : 08/05/2015 11:14 am
Isnt the sprocket spacing different between MTB and Road 10 spd?
Posted : 08/05/2015 11:34 am
Not enough to matter. A road cassette is 1mm narrower, and include a spacer.
Posted : 08/05/2015 11:37 am
got a new slx mech/shifter with sram og road cassette ... no probs
at all so spacing the same too ๐Ÿ˜‰
Posted : 08/05/2015 11:38 am
Nope, same as the MTB ones, only the cheapest don't have a carrier.
As above you will need the 1mm spacer that comes with road cassettes to get it to fit on a 9s/10s MTB freehub, It'll still index, but might need tweeking slightly to get it wo work properly at the low end.
You might be better off just getting a 10s MTB cassette and binning the big gears and usig a singlespeed kit to space the cassette out. IME the narrow gaps on a road cassette were really irritating downhill as you had to constantly search for a gear, or coast because it wasn't worth changing 4 gears between corners.
Posted : 08/05/2015 11:58 am
Best shifting I ever had was with a 9 speed Ultegra casette / 105 mech / XTR shifter (Shimano chain & those coated XTR cables), fast positive shifts & almost silent - could barely feel it... although it was also probably the last time an actual mechanic set the gears up as opposed to my ham fisted attempts ๐Ÿ˜•
Posted : 08/05/2015 12:02 pm
