Hay guys,
Just wondering if anybody knew where bouts you can get the rubber caps for frames. I've got a Lapierre Zesty 427 (doubt that makes any difference). I was playing around with using different options for internally routing some of my cables and lost a couple of the caps.
Any advice would be awesome.
Try Hotlines.
Failing that [url= http://www.evanscycles.com/products/shimano/6770-ultegra-di2-grommet-4x6mm-round-ec037142 ]these [/url] look pretty similar.
numbnut - Member
Try Hotlines.Failing that these look pretty similar.
I asked Hotlines a while ago for my 514 and they didn't stock any, but said if they found some they'd let me know - worth emailing them either way I think.
Post an update if you have any luck - i could do with some myself...
Ive had no luck with any of the bike stores which i find really odd considering internally routed cables seem to be becoming the norm. However ive had some luck! Try an automotive store they seem to have a few options.
Im also from NZ so it may be a tad different in your neck of the woods.
