RSP Plummet v Rever...
[Closed] RSP Plummet v Reverb...
8 Users
I know it's not a fair fight if both are performing as they should but bear with me!
Just sold my Reverb as I was fed up with it - brilliant when it worked but needed second IFP in a matter of months (seat pulled up when lowered - not by me!). Resigned to going back to a rigid post until droppers become reasonably priced. Would like a dropper that's reliable and easy to fix and buying a new Reverb so I get a warranty is very pricey. Anyone have any experience of the RSP Plummet? Looks good and potentially easier to fix. Only 100mm but wondering if it's worth a punt for £80. If it's less likely to bork than a Reverb (there must be a mountain of warrantied Reverbs somewhere judging by the amount of people who have had replacements) I'd be happy to try it....maybe! Any thoughts? Am I mad? Failing that, any deals around on droppers? Cheers
Posted : 01/05/2017 8:40 pm
Don't they do a 125mm plummet now? I've only ever had cheap posts (2 eTens and a brand x ascend) and they've? been very reliable so far.
Posted : 01/05/2017 8:57 pm
Cheers prawny - that's a bonus about the travel. No regrets going 'cheap' then?
Posted : 01/05/2017 9:43 pm
I've had a plummet 100mm for about 6 mounts now, and it's fine. Works nicely, only problem is that it is very picky about clamping force on the seatclamp, the lightest bit too much and it doesn't return the last few mm.... Otherwise it's great!
Posted : 01/05/2017 10:50 pm
Cheers Paul.
Bump for the back-to-work crowd.
Posted : 02/05/2017 6:40 am
had a eten for the last 18months , had plenty of abuse snet it back 2 weeks ago (2yr warranty) as I blew the canister was back within 5 days and working perfectly ,no issues with going down the budget route
Posted : 02/05/2017 7:57 am
Personally I'd buy one of these:
HTTPS://www.bike-discount.de/en/buy/kind-shock-lev-eteni-integra-seatpost-420-mm-493358/wg_id-369
(And I plan to for the Inbred!)
Posted : 02/05/2017 8:03 am
No regrets for me, I couldn't afford a reverb or similar, and to be honest I'm struggling to see how one would be much better other than having more drop (I've got 120mm now, could run 150 on my frame)
Posted : 02/05/2017 8:19 am
Sorry if it's a dull post (no pun intended), just trying to establish whether a cheap(er) post is a viable option.
Any more useful input appreciated.
Posted : 02/05/2017 8:12 pm
This seems pretty good too....anyone?
http://www.chainreactioncycles.com/brand-x-ascend-dropper-seatpost/rp-prod149024
Posted : 02/05/2017 8:34 pm
Happy with my Brand X. £105 from Ubyk too.
Posted : 02/05/2017 9:02 pm
I've got that brand x post, it's stealth only but as long as it's compatible it's really good.
Posted : 02/05/2017 9:36 pm
Cheers both - is there any kind of rebound control on it or does it 'thud' upwards like a rocket whilst crushing a nut or two?
Posted : 02/05/2017 9:54 pm
It comes up fairly gently while making a satisfying thunk sound when it reaches the top.
Posted : 02/05/2017 10:01 pm
Can you adjust it though? There must be a way of pressuring it too - an air valve like a Reverb?
Posted : 02/05/2017 10:07 pm
Non adjustable. However you can control the speed up with good control of the remote.
Posted : 03/05/2017 9:34 am
As above, comes up a good speed, certainly not enough to cause you an injury but fast enough to make a decent thunk at the top so you know it's up.
Posted : 03/05/2017 9:52 am
I've no issues recommending the Plummet. Picked up a 125mm external for my Wazoo a few weeks ago. Bar the cable being frayed when I got it (bolt in trigger tightened too much when packed I think) High on Bikes sent me a new cable within 48hrs.
Working perfectly so far.
Only gripe being the way the saddle attaches to the post. Never seen such an awkward design. Inevitably you'll end up taking paint off the mount for the cable trying to tighten the front bolt.
Posted : 03/05/2017 5:15 pm
