I am more than likely going to get some 13omm 2016 Revs 27.5 in the next few months but was just wondering if the travel can be increased? I'm not too fussed either way but as I tend to change frames quite a lot it would be nice to be able to and not have to change forks too.
yes. you have to but a separate part but its possible.
Yes up to 150mm, we have the air shafts in stock too ๐
Good stuff. Probably just made my mind up if it wasn't already.
is the conversion easy LoCo ?
I've done it on my Rebas, pretty simple with basic tools.
Guide here it's for pikes but more or less the same.
As above its a real simple job. With the right tools it's a 10minute job.
Hijack sorry ! Can 2013 solo air revs 150 travel be reduced to 130 with just a spacer?
I have a set for sale if they're any good to you.
Neil: yes pretty easy if you're happy doing lower services.
Sheepshifter: Yes they can solo air need replacement air shaft, 2012 & earlier dual air models can be reduced using spacers.
The solo airs can also have air volume tokens fitted the 2013 & 2014 will need the newer threaded topcap fitting too, 2015 & 2016 will have the compatible topcap. Again we have these in stock ๐
