rs recon air stoppe...
[Closed] rs recon air stopped working. why?
Mate text me earlier asking why his forks aren't moving, I told him to bring them round tomorrow and i'll have a look.
Rock shock recon air 140's he said they are just not moving! He assures me he doesn't have them locked out!!
They do need a service, but is there anything specific tthat could cause this? Any help welcome.
Posted : 26/05/2012 9:23 pm
They could be hydrostatically locked. Water in them basically. New fluid will be required as the current oil may look like mayo.
Posted : 26/05/2012 10:20 pm
Yeah hoping that's the problem as I can sort thatstraight away.
Posted : 26/05/2012 10:27 pm
Odds on - from me: the non bookie - the lowers are hydro locked cause the damper is leaking (right hand side) into the lowers. Probably from the inner / internal - lower damper seal.
If under warranty - that's by far the best solution. Otherwise - you'll need the inner seal, upper fluids and lower fluids.
I can only guess this after 3 forks all with the same problem.
Posted : 26/05/2012 10:38 pm
