RS Pop-Loc: Has any...
[Closed] RS Pop-Loc: Has anyone found a way of getting a good release return?
[#1282946]
I have a pair of Reba Race with Pop-loc. Having locked out the fork, on release the return is either none existant or very poor at best. I've lubed the cable, de-gritted under the cap etc but the return is poor.
Has anyone found away to get a really good snap back into the unlocked position?
A stronger spring in the fork seams to be the answer - is it??
Posted : 01/02/2010 10:17 pm
ditched mine - was shit
Posted : 01/02/2010 10:20 pm
Concur with rr; have got the manual motion control knob on order from TFT.
Posted : 01/02/2010 10:25 pm
live with it...
thats the other option
Posted : 01/02/2010 10:26 pm
Replace the gear outer with brake outer. It's a little looser fit meaning less drag.
Posted : 01/02/2010 10:27 pm
Press to release, pop up the front of the bike, pop lock will release.
Posted : 01/02/2010 10:29 pm
Fit a Middleburn cable oiler in the cable and flush it regulary
Works for me
Posted : 01/02/2010 10:30 pm
You might be able to put an extra half turn on the spring within the MC damper - but it's a faff! (having spent a good hour last weekend putting a damper back together...)
Also check to see what sort of resistance the dial on the fork has. If you have too thick a spacer/washer under it, it struggles to return. I tried an o-ring instead of the white washer, and had the same problem of sluggish return to open.
Posted : 03/02/2010 2:32 pm
well if any of you guys want to get rid ill take it off your hands 8)
email in profile!
Posted : 03/02/2010 2:58 pm
