RP23 shock set up i...
[Closed] RP23 shock set up issues (do I need a tune and which)
 hora
Basically I bought the frame separate (Meta 5) and a RP23 Kashima boost tune shock). The Tune is M/M but I'm sure it could be better/perform better.
Basically if I run the PSI high the shock is fine- runs great in a straight line but wallows when leaning/cornering etc. It doesn't wallow consistently either.
Is the shock faulty? Does it need a different tune? Help! I'm an utter-shock tuning muppet I admit too.
I'm 220lb and have tried a range between 180-230psi and it still 'collapses'/wallows in odd places.
Should I have a high compression tune to help it sit higher?
Posted : 30/05/2013 10:25 am
Have you looked at the volume spacers? That stopped mine blowing through the travel, not sure if that's the same problem as you.
Posted : 30/05/2013 10:28 am
Try fitting a volume reduction spacer before you get involved in expensive tuning exercises - it may be that the shock tune is wrong for the frame anyway, but RP23s are notorious for blowing through their travel particularly with the HV can fitted.
If that doesn't help, try LoCo or got to TFT for a Push tune.
Posted : 30/05/2013 10:29 am
 hora
Actually- possibly yes. It goes through its travel really quickly. It feels like I can never have enough air in when I'm riding. From Mojo? will have a look ta
Posted : 30/05/2013 10:30 am
Perhaps adjust your riding slightly, to accommodate for a new suspension design?
Reset the rebound/lever to zero, set the sag correctly, then go ride a similar (ideally the same) trail back-to-back, while making minor adjustments....
You'll soon find the settings which suit you...
My mates meta 5.5 (2010 vintage) has a RP2 with a M/M tune, with a low volume can, so I don't think the tune is the problem, maybe try volume adjust spacers if it has a high volume can on it..
Posted : 30/05/2013 10:31 am
 LoCo
http://locotuning.co.uk/tech-info.html setup guide.
Volume spacer will help with mid end of stroke support, when was it last serviced too?
Posted : 30/05/2013 10:43 am
I stuck a HV boostvalve jobby on my five and that was very wallowy even at high pressures. Much better now with volume reducer in, does make it harsher over small bumps though.
Posted : 30/05/2013 10:45 am
Hora, I've got either a small or large spacer, £8 posted if your interested. [url= http://www.mojostore.co.uk/acatalog/Air_Spring_Volume_Tuning_Kit.html ]They're from this kit[/url]
Posted : 30/05/2013 10:46 am
sounds like you need a new bike.
Posted : 30/05/2013 10:49 am
Has it got the boost valve pressure printed on it?
Posted : 30/05/2013 10:53 am
Out of interest, why are spacers suddenly all the rage? What's wrong with the RP23 out of the box?
Playing devil's advocate to some extent, as I'm on my second RP23 with Boostvalve (on a SC BLT), the first was fine, the second has some of the symptoms above - I can easily bottom it out at the recommended 130 psi.
Posted : 30/05/2013 10:59 am
Save yourself some pennies and get [url= http://bikes-bikes-bikes.blogspot.co.uk/2010/07/modding-rp23-simple.html ]bodging[/url]
Posted : 30/05/2013 11:02 am
 LoCo
Nothing wrong with them as such, just some manufacturers stock tunes & air can volumes can be a little to linear.
Posted : 30/05/2013 11:14 am
 hora
jivehoneyjive - Member
Save yourself some pennies and get bodging
This text says mine should be ok then?
Did this awhile back and have since moved on to coil shocks. Nothing new as it's based on a similar mod online while searching for the solution to a wallowy mid stroke and bottoming out easy on my RP23
Apparently the new 2010 RP23 with boost valve is supposed to solve the problem
Its this shock- as new so the boost valve should have sorted it?:
Boost valve tune = 225
toons - Member
Hora, I've got either a small or large spacer, £8 posted if your interested. They're from this kit
large from the non-CTD?
Posted : 30/05/2013 11:23 am
I spent a very interesting (and long) day at cwm-carn a few years ago with Orange and Mojo testing various combinations of damping tune/air volume/boost valve pressure.Doing back to back runs on different set ups.Made me realise that there is more than one way to achieve an outcome and is'nt really one magic solution that covers all styles/preferences.
 LoCo
True, various ways to skin a badger etc. 😉
Posted : 30/05/2013 11:29 am
Have you considered a hardtail? Oh... [url= http://singletrackworld.com/forum/topic/what-light-compliant-steel-frame-for-all-day-rides-to-140-150mm ]erm....[/url]
Posted : 30/05/2013 11:45 am
Apparently the new 2010 RP23 with boost valve is [b]supposed[/b] to solve the problem
Regardless of marketing bumpf, it sounds like you are experiencing the problems that this mod fixes~ worth giving it a try as it takes about 20 mins tops.
Posted : 30/05/2013 11:46 am
 hora
toons - Member
I can't believe how bloody simple it was to fit. Heres the old (left)/new. Took under 5mins without referring to instructions. First ride last night at a pumptrack/berms etc and I can actually trust the bike now. Mid bend etc it doesn't suddenly squat/wallow or act odd. I was actually leaning enough to the point I was drifting. Cheers. If anyone comes across this and procrastinates themselves. [b][u]DONT[/u][/b]
Posted : 18/06/2013 8:29 am
I did a similar thing adding tuning bands to my Monarch and it has made a real difference for the better.
Posted : 18/06/2013 8:47 am
