I have a set of Roval Controle EL's and am considering a differnt fork but can't find out if you can run them with 15mm or 20mm bolt through.
Does anyone know if it is possible to run these wheels with anything other than the standard QR?
According to the website you are stuck with qr's, it mentions the other options on the other wheels.
Hi boobs, that's exactly what i found, gutted!
I was hoping that as the hubs are DT240's i'd be able to switch over the end caps.
:cry:At least yours probably still hold air, some muppet 😕 bent his Traversee so it refuses to seal
Have you tried it with some stans??
I bent a UST rim on an old wheel and managed to get it sealing again with some gently rim tapping using wood blocks.
The 2011 Roval EL, SL can be converted to 15mm axle
