Rounded bolt in Sha...
[Closed] Rounded bolt in Shamino disc caliper (holds pads in) -how to remove?
 hora
[#790630]
A really strong pair of pliers? Is there an 'easier' way? Its a c2mm allen key to remove
Posted : 17/08/2009 9:43 am
tap a torx head in?
Posted : 17/08/2009 9:45 am
 hora
Can you get one small enough? Typically I need to change the pads (worn out).
Posted : 17/08/2009 9:46 am
you can get tiny torx heads, got to do this to my hope mini's next time the pads wear out (Damaged it putting some in this weekend)
Posted : 17/08/2009 9:48 am
Or tap in a 2.5mm allen
Posted : 17/08/2009 9:51 am
A 3/32" allen key is slightly bigger than 2mm so may do the job.
Posted : 17/08/2009 10:09 am
I was in the same situation, and a guy in a bike shop did the following, and it came out a treat.
[list=1]
[*]Put the correct allen key in.
[*]Got a set of molgrips and clamped really hard round the bolt head.
[*]Turned the allen key and molgrips at the same time.
[*]Bob was his uncle.
[/list]
I watched only, so not sure if there is a knack that I couldn't see, but it looked easy.
Posted : 17/08/2009 10:18 am
You'd be hard pushed to get a set of molgrips onto the bolt that hold in pads on Shimano calipers
Posted : 17/08/2009 10:21 am
how the **** do you round that bolt anyway?
Posted : 17/08/2009 10:22 am
Ah, sorry, it was a disk bolt that I had rounded, not a caliper bolt.
Not awake yet.
...but surely if he can get pliers on it, he can get molgrips on.
Posted : 17/08/2009 10:25 am
 hora
Right, let me have a go tonight with the molgrips and allen key- if not will whack in a slightly bigger allen key.
How did I do that? I'm hamfisted.
Posted : 17/08/2009 10:30 am
[i]jam bo - Member
how the **** do you round that bolt anyway? [/i]
using crap allen keys (even though I posted a thread on what decent allen keys to buy last month), and just tightening it too much...
Posted : 17/08/2009 10:31 am
what caliper is it? most shimano ones ive seen use a 3mm allen key. Magura Marta use 2mm and is teeeeenny!
Posted : 17/08/2009 10:32 am
 hora
Saint caliper (same as older XT)
Posted : 17/08/2009 10:57 am
pretty sure thats a 3mm, the 2.5mm i have for my ODI's (and frequently pick up by mistake as it isnt marked with the size) is too loose.
Posted : 17/08/2009 12:08 pm
Did you have any joy with the molgrips?
Posted : 18/08/2009 4:57 pm
drill it!
Posted : 18/08/2009 5:00 pm
z1ppy - Member
jam bo - Member
quite unbelievably i have just tried to find said thread, plumbing new depths of biking geekery, and can't. linky link!
Posted : 18/08/2009 5:05 pm
[url= http://www.singletrackworld.com/forum/topic/3hrs-to-remove-a-rounded-allen-boltnow-i-can-go-for-a-ride ]thread[/url]
Use a pin punch or impact driver to close the bolt around the allen key worked for me , after i tried cutting a slot in it to use a screw driver which after 1 hour of hammering left me with 3/4 of a mangled head. Good luck
Posted : 18/08/2009 5:17 pm
Why did you have to tighten it up so much anyway?. It's not carrying any load and with the wee split pin on the end it can't come out.
Posted : 18/08/2009 5:20 pm
theflatboy - Member
[i]z1ppy - Member
jam bo - Member
using crap allen keys (even though I posted a thread on what decent allen keys to buy last month), and just tightening it too much... [/i]
yep I went searching for it too (gunna buy some now!) but it turns out it was a post not a thread...
http://www.singletrackworld.com/forum/topic/anywhere-sell-extra-long-allen-keys
Posted : 18/08/2009 5:56 pm
sweet. 🙂
Posted : 19/08/2009 11:11 am
 hora
[i]Did you have any joy with the molgrips?[/i]
Nope.
Larger allen key hammered it- a rounder and bigger hole now!
Why do I overtighten? I overtighten everything including car wheel nuts (sheesh). Taking it down to be drilled by the LBS. Kinda need new pads in soon...
Posted : 19/08/2009 11:14 am
These are what you need.
http://www.trssupplies.co.uk/index.php?_a=viewProd&productId=16087
Posted : 19/08/2009 11:40 am
Hora - use an impact driver , or pin punch even a small drill head to close the head around the allen bolt, trust me it works and will save you a few bob . Its easy
pin punch
Posted : 19/08/2009 3:13 pm
I had a similar problem. I used a dremel to cut a small slot in the top and used a flat screwdriver.
worked a treat.
Posted : 19/08/2009 3:19 pm
