Rotor size for Coti...
[Closed] Rotor size for Cotic bfe
Just building my new bike & iam after rotor sizing for rear brake.
Posted : 11/09/2012 8:43 pm
Depends on you and the build.
I like 'assertive' brakes, so my XS BFe runs a 180mm rear and 203mm front (2012 XTs).
This might well be overkill for most people. Unless you weigh WAY more than me (13 stone or so I guess), 160mm rear and 180mm front ought to me more than enough.
slainte ๐Ÿ’ก rob
Posted : 11/09/2012 8:50 pm
The BFe doesn't have a post mount rear brake so you will need to use a mount whatever rotor you use.
As above, use what suits your riding style. I'm a skinny XC mincer so I'm using a 160mm rotor as it also means my wheels are interchangeable with other bikes.
Posted : 11/09/2012 8:54 pm
180 front, 160 rear is most common these days. Why not go 180 all round to be different?
Posted : 11/09/2012 8:56 pm
183/203 here
Posted : 11/09/2012 9:44 pm
Dinner plate 200 on front, 180 rear for me.
Posted : 11/09/2012 10:30 pm
203's all round ๐Ÿ™‚
Posted : 11/09/2012 10:39 pm
Don't know about the latest iteration of the Bfe but the last one had a limit of 180mm for a rear rotor. I've got a hope 183mm in mine and there's definitely no room for anything bigger!
Posted : 12/09/2012 6:54 am
203mm/180mm here.
More than enough for my riding!
Posted : 12/09/2012 7:01 am
depends on many things, your weight, riding style and most of all the brakes...
I tend to run 160/140 with modern brakes cos they're so powerful anyway and absolutely HATE brakes with too much bite, I find using smaller rotors helps calm them down and I don't have issues with overheating, bizarrely pads seem to last longer too :-s
I'll run 180/160 if they are a bit older and not quite as powerful, eg older hope minis etc.
I tried 200mm rotors for a while but they just upset me by being too powerful and too grabby, but with most bike things it's personal preference, easy enough to go up or down anyway.
Posted : 12/09/2012 8:06 am
