Roofing Felt - Is i...
[Closed] Roofing Felt - Is it grippy
Anyone else tried covering slippery planks in roofing felt. Does it work ?
Or there any better economic way to get some northshore rideable before spring...
Not chicken wire
Posted : 11/02/2020 2:03 am
Well, at first. Sort of.
But only til the grit wears off (pretty fast). Plus it’s fragile and will wear & rip very fast. Not really suitable.
Which is why folk use chicken wire, sorry.
Posted : 11/02/2020 2:36 am
Mix sand into paint. Paint.
Wears out too but might last better than roofing felt. You can get epoxy-based floor grip compounds.
Why not chicken wire?
Posted : 11/02/2020 5:02 am
Mind you, if your boards are all outside in the damp, painting might not be feasible anyway.
Posted : 11/02/2020 5:20 am
As above, I doubt felt would last very long.
What about this kind of stuff?
Grip tape
It's designed for things like stairs, so is intended to withstand a bit of 'traffic'. I'm sure if you Google around enough, you could find some in a width suitable for your needs...
Posted : 11/02/2020 8:06 am
 Spin
Rotary wire brush along the grain to expose more grain. You could also do this with a pressure washer & sand blaster attachment.
Posted : 11/02/2020 8:23 am
Painfully slow but cutting a checkerboard style pattern with a chain saw/circular saw?! Which would technically do the same as chicken wire maybe?!!
Posted : 11/02/2020 8:57 am
especially in areas such as ramps
Sweet, who would have thought there was such a specific product available?
Will probably be OK away from jumps too.
Posted : 11/02/2020 10:03 am
no its not grippy
Posted : 11/02/2020 10:04 am
You could hammer in fencing staples leaving slightly proud to give your tyres something to bite onto.
I expect normal nails again left slightly proud could work too.
Posted : 11/02/2020 10:00 pm
I wonder how many people saying "no" have tried it?
There's a short section of North shore on one of our best local trails, built by a roofer and covered with felt.
It gets low traffic but has held up very well through some harsh conditions for at least five years.
So I'd give it a go myself.
Posted : 11/02/2020 10:09 pm
 Bez
Probably quite a difference between shed felt from B&Q (which doesn’t last long even on an entirely bicycle-free shed roof) and professional stuff.
The low end stuff certainly won’t be worth bothering with, I’ve got a roll of it in the shed and you only have to sneeze within ten feet of it and all the grit falls off.
Posted : 11/02/2020 10:23 pm
 jedi
Deffo don't cut checkerboard as water sits in and excellerates rot. We gVe up on grip solurions and just wait for it to dry. Although I do petrol burn some sections just to ride
Posted : 11/02/2020 11:14 pm
 jedi
Posted : 12/02/2020 9:08 am
Theres some really thick torch on stuff 4.5mm, far superior than B&Q stuff for your shed.
Posted : 12/02/2020 9:24 am
 jedi
Tyres wear felt out really quick
Posted : 12/02/2020 9:26 am
Chicken wire is what I’ve always used - seems to work well enough and is cheap.
Posted : 13/02/2020 12:26 am
 jedi
Tyres rip it too quick and holds water on the woodwork too accelerating rotting
Posted : 13/02/2020 11:08 am
