[Closed] Rollers
 Sam
pedalhead - Member
Are there any rollers that are better suited to out-of-the-saddle mashing?
The free-motion type setups as linked above definitely better for out of the saddle efforts.
Posted : 15/11/2012 8:30 pm
Cheers Sam, I feel a project coming on...
Posted : 16/11/2012 9:53 am
Here's a little vid to give you some idea of the noise. I took this about a year ago, when I was learning how to use them, so wanted to review my 'form' (which was pretty dreadful). They are sat on a suspended wooden floor, so really loud, and the rattle is from the drive band hitting the floor at certain revs.
Posted : 16/11/2012 12:11 pm
GavinB, you need to pedal faster, thats a very slow cadence for the rollers. Its much easier if you are around 90-100rpm (or over if you can)
Posted : 16/11/2012 12:27 pm
Are there any drills? I've tried doing pyramids, going up and down the gears, going down to really low cadence, then back up to a faster (easier) cadence. Some more ideas would be good.
Yes, agree about the cadence. I wobbled like a goon for the first few weeks, then sped up. Alarmed myself a few times, whilst wearing earphones, and yelping really loudly, as the bike swerved almost off the rollers whilst belting along at '35 mph'.
Posted : 16/11/2012 12:35 pm
Gavin, put them on a hard rubber mat - one of those exercise mats you see at gyms. It'll damp the noise down significantly without being so soft that the rollers dig in. For even better insulation, stick an old foam rollmat under the hard rubber mat.
Posted : 16/11/2012 12:39 pm
create better resistance?
They have.
Kreitler use a fan to create resistance and flywheels to maintain inertia. Also go for the medium rather than standard diameter rollers for more resistance. You can also go for small, but will need to be a US track champion!
Im fighting the need to use mine at the moment. Hate them with a passion, but 30min (tried 1 hour, was torture) sessions 2 to 3 times a week do work wonders.
Tried a turbo but for some reason I got chronic knee ache. Went back to the rollers and its been fine.
Posted : 16/11/2012 12:54 pm
Woh! i didn't know about these. Is it more resistacne the the alu cyclops ones? Surely this would work with my cyclops ones?
Posted : 16/11/2012 1:00 pm
@ Crazy-legs: Good idea, I'd tried to bodge something with a few random doormats, but nothing really worked, so will grab a gym matt. The rattling used to annoy Mrs B more than anything - I just zoned out (mostly with intense concentration). 😀
Posted : 16/11/2012 1:08 pm
The Headwind Fan is an adjustable resistance unit providing a wide range of resistance options depending on how far you open the air inlet. The air flow can be aimed at the rider for a cooling breeze, or directed away if preferred. The range of resistance when used in combination with the 4.5 rollers simulates everything from a 2mph tailwind to a tough uphill climb into the wind!
Awesome!
Posted : 16/11/2012 1:12 pm
Page 2 / 2
