Looking to reduce the travel from 170 to 140. Is this possible?
Posted : 26/07/2017 1:48 pm
yes with replacement air shafts, seemingly the same shaft used on pikes, though it would seem the pike shaft travel does not translate to the yari (10mm more for the 29er).. any one want to confirm?
Posted : 26/07/2017 1:54 pm
It's possible, you can change the air shaft to alter the travel. I can't think off the top of my head which air shaft you need, they are interchangeable with the pike/ lyrik air shafts.
Posted : 26/07/2017 1:57 pm
I think you can with some and not others, they come in 130mm to 180mm lengths so you're almost going full range but it might work.
Whilst they are a 'bitsa' fork, they do now at least have a full parts list of their own, so youy don't have to try to work out which Pike 29er airshaft it uses etc.
Posted : 26/07/2017 1:58 pm
Posted : 26/07/2017 2:00 pm
