Rockshox Super Delu...
Rockshox Super Deluxe Ultimate rebuild advice….have I goosed it?
Long story short, picked up a cheap RS SD ultimate off eBay that had been sent to TF and diagnosed with not economical to repair. Damper body worn but still very smooth.
I fancied a possible upgrade and little project…with no experience of taking apart shocks!
Shock came partly disassembled (from TFs inspection). Initially noticed the Threshold lever was a bit floppy side to side but assumed that was as the chambers had been emptied of oil. [url= https://i.ibb.co/c3GsB9G/980-E4-CD9-96-C8-4-D70-9-A25-2738-A8145-AD5.jp g" target="_blank">https://i.ibb.co/c3GsB9G/980-E4-CD9-96-C8-4-D70-9-A25-2738-A8145-AD5.jp g"/> [/img][/url]
[url= https://dedupelist.com/ ]de duplicate[/url]
Put it all back together with fresh 50hr seals, bled it, made lots of mess. Inflated the piggyback to 250PSI and it felt very firm to compress. Wondered if it would change when I add air to the air can….feels the same. Haven’t mounted it on a bike yet but had assumed (limited knowledge from old shocks) that without air it should compress very easily. Is the piggy back system different? The threshold lever is now firm and flicks from one side to the other fine…but could that be a problem with compression? Any pointers would be great before I make any more oily mess!
Chris
Posted : 02/10/2022 11:33 pm
It takes a surprising amount of force to compress a shock with no air/spring in my experience. Put it in the bike and see what happens
Posted : 02/10/2022 11:52 pm
Thanks @mashr that’s positive news….Waiting for a bushing tool to arrive then I’ll try that.
Posted : 03/10/2022 7:37 am
I would agree with above, it's not usually easy to compress a shock even without air. They're designed for a lot more leverage than a fork so don't move the same without air
Posted : 03/10/2022 9:48 am
Great, thanks DC…think I’m showing my lack of experience with shocks then! Reassuring.
Posted : 03/10/2022 5:22 pm
