I noticed my Reverb was sagging a bit after the last ride, so I pumped it back up to 250psi (it was down to 200). Now when I sit on it it keeps going down. The post will still return quickly when the lever is pressed. What is the likely cause?
I've had the same problem. I bled the hose today as thats meant to sort the issue but that hasn't worked (the hose is now litterally air free).
When I sit down its dropping by about half to three quarters of an inch.
Fatties ๐
๐ Seems okay now I think my shock pump was leaking air and I hadn't actually pumped it back up.. Try pumping it up ben
Hi guys,
I had the same problem and asked on here last week.
in the end-by luck I found the o ring on the inner seal head had blown out, replaced and now is good as new.
