rockshox revelation...
[Closed] rockshox revelations
6 Users
Just to delivery of my 2013 rlt and see its post mount, ive been running is in the past i use 180mm rotors will i need an adaptor?
Also it came with Lh poplock does that mean it goes on Lh side of the handle bar?
Posted : 28/01/2013 5:58 pm
yes
you could try it on the other side but it may be a bit awkward to use
Posted : 28/01/2013 6:19 pm
If you've got IS mount brake callipers the the adaptor to mount them to a post mount fork also means you'll have to go up to a 200mm disc as well. I did it, and to be honest it's a bit of a heath-robinson affair 😐
Yes. It'll be all wrong on the other side. Left hand side is correct anyway. 🙂
Posted : 28/01/2013 6:37 pm
Why will i have to go to a 200mm rotor
Posted : 28/01/2013 6:51 pm
You may not need to go up a size. I had an IS mount adaptor that fitted on to post mount fork for a while and didn't need to change the rotor size. I think it was kcnc one, will try and find a link for you.
Posted : 28/01/2013 7:45 pm
www.chainreactioncycles.com/Models.aspx?ModelID=54881
This i guess
Posted : 28/01/2013 7:48 pm
This...
http://clee-cycles.co.uk/esite/P1043/product
Was tight fit on my hope mini, may be ok with different callipers.
Posted : 28/01/2013 8:06 pm
Because if you have IS calliper, they aren't designed to be used with an adaptor at all. Add an adaptor and the calliper moves out, necessitating a bigger disc.
If you had a post mount calliper, you just buy the correct adaptor and you're sorted.
Andy9678, it depends on it he has an IS or post mount calliper mate!
Posted : 28/01/2013 8:27 pm
I'm running shimano xt 785 if that helps
Posted : 28/01/2013 9:08 pm
So you just need a +20mm post-mount to post-mount adaptor.
The one you linked to will be fine, but there are cheaper options ( http://www.chainreactioncycles.com/Categories.aspx?CategoryID=563). The Avid ones seem to be the cheapest.
Posted : 28/01/2013 9:28 pm
Avid mounts won't work with XT calipers as the mount relies on the CPS washers to take out the misalignment between the caliper body and the bolts (if you look at an Avid mount, the front and back posts aren't the same size).
I've got a 5 ride old shimano mount gathering dust if you want it for £4 posted, e-mail d4vew4lsh at gmail dot com if interested.
Posted : 28/01/2013 10:10 pm
I've used Avid ones with SLX brakes. Sometimes they need some spacing out, can't remember if it's every time. But yeah, there are occasionally weird issues with adaptors and it's perhaps safer to stick with the same brand as the brake.
Posted : 28/01/2013 11:43 pm
