I noticed this morning that I am losing travel on my 2014 Revelation Solo Air 140mm.
The fork is sagged 20mm into it's travel without any loading.
I emptied the solo air chamber with a shock pump and pumped it up again to 110 PSI (which is what I usually run) and the problem didn't go away.
I pumped them up to 140PSI and this increased the travel by 10mm but I am still losing 10mm of travel and this is not the ideal PSI for the type of riding I usually do.
I did notice on my last ride that the fork bottomed out when I landed a small drop off but I am not sure if this is because I had lost travel before attempting it or if this has caused the travel loss.
Could Loco or anyone else asked any light on what could be the problem please?
Take a look [url= http://singletrackworld.com/forum/topic/revelation-forks-sucking-down ]here.[/url]
You aren't the only one.
