rockshox revelation...
[Closed] rockshox revelation 2009 oil leak
Oil leakage when i have the shock pump attached to botom air Chaimber on my rockshox revelation 2009
pls help
Posted : 17/01/2011 6:57 pm
When you release the air pressure, you'll get a bit of oil coming out.
Edited to add:
From the [url= http://www.tftunedshox.com/faq/rock_pike_reba_revelation.aspx#link6 ]TFTuned website[/url]
When I alter the negative air pressure in my air fork, there's oil at the valve. How can I stop this?
The oil is lube from the air chamber which collects at the bottom of the fork during use. To prevent the oil weeping, simply tip the fork upside-down before checking/altering the negative air pressure.
Posted : 17/01/2011 7:00 pm
