Rockshox Recons - c...
[Closed] Rockshox Recons - change travel
 StuF
I've got a pair of recon 335 SL (100mm coil) - I think these are OEM ones and they could do with a bit more travel.
Anyone know if I can get these upped to around 115/120 without huge cost (ie before it comes worth my while changing for some nice revs/rebas)?
Posted : 28/07/2009 2:22 pm
Im pretty certain that OEM Recons cant be adjusted internally for travel. Give TFT a call to clarify i would say.
Posted : 28/07/2009 7:24 pm
I've got some too; don't think travel can be changed.
Posted : 28/07/2009 7:26 pm
 JxL
I had a similar issue with Reba's, and been told various things by TFT and other shops which turned out to be untrue. Ring these guys, I believe they are distributors of Rockshox stuff in the UK and know thing or two about it.
http://www.fisheroutdoor.co.uk/public/index.php/brand/sram/contact.html
It turned out my reba's could not be upped from 100mm to 120mm, but only lowered to 80mm. Then again your forks are coil and different model, so best of luck!
Posted : 28/07/2009 7:54 pm
JxL, what model of Rebas were you unable to extend to 120mm?
Posted : 28/07/2009 8:55 pm
 StuF
Response from fisher:
[i]The Recon 335 SL can have a travel change done. However many of the internal parts would need to be changed. The rebound damper spring shaft and spring would all need changing the total cost of this would be £98 without any labour[/i]
- so it'll be some second hand revs/recons at some point instead
Posted : 29/07/2009 4:27 pm
