My Reba's have the poploc, or rather they have the [u]ability[/u] to poploc as I lost the poploc a long time ago.
So I'm left with the adjuster on the top of the right leg, which is useless as it needs the poploc in order to function.
I could source another poploc but don't really fancy it as I don't want my handlebars cluttered with one.
Can I swap my adjuster, for something else which will let me adjust the forks?
You mean a lever on the top of the fork leg that does the locking-out job?
I want one of those too. I'd be interested to hear how easy it is to swap the mechanisms over.
i lost he grub screw before I ever installed poploc. My friend uses his quite a lot, but says it takes about half an hour a muddy ride before it's sticking and then he has to click the bar lever, then pull the cable at the fork leg anyway!
we covered this this morning. keep up ๐
http://www.singletrackworld.com/forum/topic/peterpoddys-poploc-conversion-guide
Just convert the fork to crown mounted lock out!
Here you go -
๐
EDIT
Cheers Thom, you beat me to it!
Cheers PP.
HA - brilliant thomthumb and PeterPoddy - nice timing.
