Rockshox Reba RL Po...
[Closed] Rockshox Reba RL Poplock 110mm Fork - Raise to 120mm?
Greetings,
Can one turn the above fork into a 120mm fork? Normal with RS forks they have a platform and then adjust the travel within the boundaries of the design with spacers, but I can't work out if that is the case with this fork. One can buy a 120mm travel Reba, so it makes sense that I can squeeze an extra 10mm out of it. Innit?
Oh, and this is the 29er fork.
Posted : 13/07/2013 4:04 am
One bought a 100mm Reba 29er thinking that one could make it a 120mm fork. One was shocked to find that the max it could go to was 110mm. Yours may be the same.
Posted : 13/07/2013 8:13 am
 nuke
The only real way one can find out is to open them up and see there is a a spacer in one's forks. Are they aftermarket forks or off one's off-the-shelf bike/OEM?
Posted : 13/07/2013 8:18 am
Should be ok as they usually are either 80-100 or 100-120 afaik?
Posted : 13/07/2013 9:19 am
Thanks for the differing advice ๐Ÿ˜€
Yep it's an OEM fork so I'll probably get off my arus and pull it apart anyway.
Posted : 14/07/2013 1:16 am
