Rockshox Pike Charg...
[Closed] Rockshox Pike Charger dampers
[#12356149]
I'm building myself a 'nice' bike with some newish bits and some parts bin bits.
For the forks I've got some Pike select+ from the CRC sale that are currently on my hardtail. I want to put these on my new bike so I bought some second hand pikes to put on the hardtail. These came with an upgraded charger damper.
According to TrailHead the CRC select+ have a CHARGER 2.1 RC damper. Is there any merit is swapping dampers? Is one likely to be better than the other?
CRC select+
Second hand
Posted : 22/04/2022 10:57 am
The select+ damper should be the better damper. It’s a 2.1 charger with lsc and lsr adjustment.
The older one you have there is a charger 2 damper by the looks of it - the rct3 version so it has lsc adjustment in open and then the 2 lockout sort of style settings. Also has lsr.
Posted : 22/04/2022 11:03 am
+1 it's really good.
What you might want to look into doing though, is updating the air spring on the older fork.
Posted : 22/04/2022 11:05 am
Ride em...see if you notice the difference. 🙂
Posted : 22/04/2022 11:07 am
The Charger 2.1 in the Select+ is superb. Its the current top level, just misses the individual adjustments (high and low speed) you would get on a Pike ultimate currently.
Posted : 22/04/2022 11:09 am
Great. Thanks, saves me some work. The spring has already been upgraded in the 2nd hand one too.
Posted : 22/04/2022 11:30 am
