RockShox Pike 29 qu...
[Closed] RockShox Pike 29 question
Hello Crowdwisdom.
Pike 29 Solo Air forks – can they be 'chopped' to run at 120mm [i]without[/i] having to buy them attached to a Specialized Camber Comp Evo?
Thanks in advance.
Posted : 21/01/2014 1:48 pm
 LoCo
Yes, either by machining the air leg or by replacing the air spring system ( not In uk yet due in month or two)
Posted : 21/01/2014 1:53 pm
Thanks LoCo. Is that a job for TFTuned or someone similar?
Posted : 21/01/2014 2:02 pm
 LoCo
Errr think we maybe able to help 😉
Posted : 21/01/2014 2:03 pm
Er, or indeed yourselves, LoCo?
(Note to self; check who is answering your questions next time)
Posted : 21/01/2014 2:05 pm
Lol
Sorry for the gaff, LoCo.
Embarrassed.
Hi Loco, small hijack if you're still on here... Can you machine the leg now (without the fabled parts) and if so can it be reinstated to 140mm with new parts afterwards or is it the CSU/lowers that get machined?
Posted : 21/01/2014 2:47 pm
 LoCo
All adjustments are done to the air spring assm. So change of that to 140mm wi give you back the travel, no mods to the chassis
Posted : 21/01/2014 3:10 pm
Thats usefull to know - what kind of price to convert pike 29's to 130mm, using the conversion parts so it can be reversed?
Posted : 21/01/2014 3:12 pm
