Rockshox maxle
[Closed] Rockshox maxle
[#11249451]
Just picked up a set of Pike ultimate with a bolt through axle.
i assume if I buy a Rockshox QR Maxle It’s a direct swap?
have I assumed right!!!
Posted : 15/06/2020 11:30 am
Yes, so long as it -
The correct length axel, thread pitch, thread length and 15mm
Posted : 15/06/2020 12:37 pm
I'd stick with the bolt-through tbh. Less to go wrong. Though you do need to carry the right allen key - or make sure it fits one on your multi-tool.
Posted : 15/06/2020 2:42 pm
If you want a QR version then go for the Brand X one of the correct size. The Rockshox Maxle design is poor and this is exacerbated by some if it being made out of cheese.
Posted : 15/06/2020 2:46 pm
What BWD said.
Although if you do want to buy a new one I've got one that came straight out of my forks that I swapped for a bolt through one.
Posted : 15/06/2020 3:06 pm
Yes, but it's not as good- the current maxle has a slightly weak lever that can snap in normal use.
(and really, how often do you ever want to take a wheel out, when you don't also have tools convenient?)
Posted : 15/06/2020 5:05 pm
Ahh
so the bolt through is better. It came a bit loose yesterday but I’d not noticed the torque settings stamped on it when I did it up..,,
I’ll try again, and make sure I can get it undone with my multi tool!
cheers all
Posted : 15/06/2020 6:40 pm
