Rockshox Lyric Coil...
[Closed] Rockshox Lyric Coil Servicing, Advice needed
6 Users
What parts are needed? I realise i'll need seals but is the damper seal kit needed too? i was going to service the motion control as well.
Is it a straight forward job?
Posted : 22/06/2010 2:47 pm
The damper is pretty simple (as a design) isnt it? I would just leave it until something goes wrong then just change the o rings.
Posted : 22/06/2010 2:49 pm
 IA
Mission control not moco in lyriks. It's more complex than Moco but you shouldn't need to take that apart, just take it out and clean it. Replace o-rings if worn.
Similar complexity to servicing any other RS - not bad.
Posted : 22/06/2010 2:50 pm
I was just going to replace the o rings. Is that the damper seal kit? how often should the motion control be serviced?
Posted : 22/06/2010 2:52 pm
sorry mission control
do you need a tool to fit the seals? a seating tool?
Posted : 22/06/2010 2:54 pm
They recommend a seating tool but it isnt necessary just push with your palm or fingertips they arnt normally in very tight.
Posted : 22/06/2010 3:13 pm
Are the seals leaking? If not why change them?
Posted : 22/06/2010 3:14 pm
The kit to service the MiCo unit isn't expensive (£20ish) and includes new o-rings plus the glide-rings for the dampers. Easy to do. Seems to have reduced (if not eliminated) the amount of oil that comes out through my MiCo knobs.
Posted : 22/06/2010 7:28 pm
as everyone's said - it's very simple - you just need to be sure of the oil height / volume when you put it back together. Think it should be 115mm from the top of the threads...
Posted : 22/06/2010 7:52 pm
