rockshox dual air /...
[Closed] rockshox dual air / dual position air?
 ed34
[#3134914]
just trying to work out what this does, but cant find an instruction manual on the rockshox site (the user manual you can download just mentions the quick release and fitting the fork)
So..
Dual Position Air allows you to adjust the travel on the go? Like Fox's Talas thing?
Whats standard Dual Air then? And if you cant adjust travel on the go with this, can you fit the dual position air part at a later date?
Posted : 10/09/2011 9:36 pm
I've got Revelation RLT Dual Air forks. Dual air is just two air chambers, the Pos air adjustable via the valve on top of the fork leg, the Neg air adjustable via the valve on the bottom of the same fork leg.
Oh, & the travel is set at 150mm. To adjust travel is a strip down & fit internal spacer job. Two 10mm thick spacers came with the fork, so I could have 140mm or 130mm if I wish.
EDIT: Dual Position Air is exactly what you are thinking of.
Posted : 10/09/2011 9:41 pm
