Where can you buy crush washers for pikes by themselves? All i can find so far is the whole service kit on TF tuned which i really don't need! And also where can you find all travel spacers for pikes
I have a set of the all travel spacers spare if you want to bu them off me?
£12.50 from TFTUNED
£8 posted from me
I'll probably end up taking them actually, just need to check a couple of things first! Any idea where to get the crush washers from?
jonnych-i would love to find out aswell.i snapped the large one on the bottom of the air side on my recons.
by the way iv,e talked to tim and you have to buy the full service kit.
So all i need is a couple of crush washers which probably cost all of about 2p to make, but I have to buy a full £25 service kit?
do you want the spacers?
robjackson@hotmail.co.uk
I lost the bolt and crush washer on the bottom of the U-turn side of my coil Pikes and replaced it with a standard bolt and washer from a local hardware shop. Only used it a few times since then but it doesn't seem to be leaking oil.
Someone will be along to tell me I'm doing something really silly.
Rob - what do you get in the set, and are they used or new?
Grumm - can't see anything wrong with it to be honest, hopefully someone can confirm if this is ok
a 10mm spacer and a 20mm spacer - new/unused
Ok i'll have to leave it then i'm afraid, I need a bit more than that!
