Rockshox charger 2 ...
[Closed] Rockshox charger 2 swap ?
[#10662186]
I think I know the answer to this but just making sure
So a set of 2019 Lyrik rc2 650b forks and a set of 2019 rc yari forks 29er are the dampers interchangeable IE I want the rs in the 29er yari and the rc in the lyrik ( both debonair )
the 29er is 160mm the lyrik 170 mm
Will the damper just swap over with a lower leg service ?
cheers
Posted : 09/06/2019 7:15 pm
Should be ok as long as the charger 2 is long enough or longer than the air shaft of the forks u are putting it in to. Also the bore diameter and threads will have to be same.
The rc's will have the oil loose inside the leg of the fork though with a separate compression and rebound damper. The charger is obvs 1 piece.
Also if there's no internal notch on the bottom of the stanchion of the forks currently with the charger damper you won't be able to convert it to RC. As the notch is needed for a circlip to hold the rebound in place.
Posted : 10/06/2019 4:45 pm
Thank you , ive since spoke to Slik in Macclesfield who confirms it should be a straight swap over 🙂
Posted : 11/06/2019 9:21 pm
