Anyone know if you can swop the springs between the pikes/lyrics/sektor 85mm-130mm u-turns into a set of Revelations .The Recons had the same springs . After a x firm (black) spring ,struggling to find a second hand/new other than in medium ,so I may possibly go down the 'spares and repair fork' route.
Posted : 08/09/2015 9:49 pm
Don't think Lyrik U-turn springs will - top cap too large a diameter. Others should.
I managed to get a Psylo U-turn spring into air U-turn Revs after I scratched the air tube. Needed the Air top cap, though. Worked spot on and bumped travel up 5-10mm, somehow.
Posted : 08/09/2015 10:25 pm
Yes you can between Pikes/Revs but the shorter x-firm spring in the longer fork will be softer.
Buy the correct part
Posted : 08/09/2015 10:42 pm
