Just picked up a 35 Gold Rl and need to drop the travel with a single 20mm spacer.
The spacer kits I've seen are £15+ and pretty much out of stock in most cases.
In true skinflint style, I don't fancy paying £15 for a single plastic washer and be left with a dozen others that I don't need.
Has anyone fashioned or sourced their own?
Or know where to find single spacers?
Anyone else able to advise?
What does it look like - I have a spacer from a Pike I don't need if it's the same design you can have it. Msg me if any use.
I use these-
on our Suntour forks (10mm diameter shaft). Just cut an 8mm or so gap in them using a hacksaw, tidy the ends up and they just clip over the shaft. There's no need other than to be able to shaft (arf!) people for more £££ to have different length spring shafts in air forks.
Amazon had them a few months ago. 32mm and 35mm top caps (depending on fork) with several spacers/tokens.
The travel adjust spacers for air shaft on the 35 forks are the same as the cheaper XC30, XC32, Sektor etc.
Part number 11.4018.034.000
